Nick Halstead Posted November 15, 2015 Report Share Posted November 15, 2015 (edited) So I know not all things are made perfectly and here's a few things I have found wrong with my Edge so far. Figured I'd start documenting it all and then start some trips to the dealership. Not in pics are 2 spots where the paint has runs that I found after waxing or the condensation on all 3 parts of the rear tail lights. Bottom Trim Middle Pillar Trim coming up at top Middle Window Trim doesn't seem to want to sit flush at the top corner Bottom Trim Odd bubble on hose By far the worse piece. It's warped Doesn't sit flush with the rest either Same on this side but not as bad This piece does the same as the other side, makes me think it's supposed to be this way, but the rubber has a lip that it looks like the trim is supposed to sit in and it's slid underneath the plastic pillar piece. This is crazy, only my passenger door is flawless with these bottom trim pieces. Again, the other door. Pillar trim coming off at the top corner. Different View. Edited November 15, 2015 by Nick Halstead 3 Quote Link to comment Share on other sites More sharing options...
Chipster Posted November 15, 2015 Report Share Posted November 15, 2015 Nick; Are you getting any wind noise that you can directly attribute to those failing trim / sealant locations as far as you can tell? Quote Link to comment Share on other sites More sharing options...
cds71 Posted November 15, 2015 Report Share Posted November 15, 2015 (edited) Nice observations. ...I'm gonna take a closer look on my 2015 sport. .....just took a really close look at all the key areas you documented. .....and mine is flawless. ...not one area has any lifting or deviation...I would seriously be talking to your dealer about these issues. My edge has a build date of July 14, 2015....as per Vin. ....this is my second edge sport....the first one built in march had massive leaks...and ford gave us this one to replace the first one. Edited November 15, 2015 by cds71 Quote Link to comment Share on other sites More sharing options...
Vadimus Posted November 16, 2015 Report Share Posted November 16, 2015 You did not add a cherry - the sweating tail light bar! Damn, I'm lazy, but I'd kill took her to the dealer for much fewer issues... Quote Link to comment Share on other sites More sharing options...
tron1974 Posted November 16, 2015 Report Share Posted November 16, 2015 Nice job with the pics and all. I will also take a closer look. I have a build date of Feb. I have other fit issues that I need to get addressed. I'll try and get some pics. I have another thread I created somewhere. My issues: The carpet on the passenger side front does not fit tight and blocks the floor lights because it is pulled away from the side. Both rear small window molding look warped My headliner on the driver side does not fit within the rubber molding and slightly hangs My issues is that will the dealer be able to replace these items without making more issues or rattles? Quote Link to comment Share on other sites More sharing options...
