mcali6301 Posted November 12, 2015 Report Share Posted November 12, 2015 Looking to whether or not to do this myself. I'm seeing so much conflicting info on how to do it. This link seemed to be the best but then I noticed it as 2007-2010... http://www.carcarekiosk.com/video/2008_Ford_Edge_SE_3.5L_V6/coolant_antifreeze/flush_coolant Does the 2011 have a petcock? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 12, 2015 Report Share Posted November 12, 2015 Wait ... there's a problem other than the meandering one??? J/K! Yes, there is a radiator drain plug, located at the bottom driverside of the unit. Part 8115 in the attached PDF diagram. 2011 ford edge radiator drain plug location.PDFFetching info... 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted November 13, 2015 Report Share Posted November 13, 2015 And here i drilled a hole and drained it then plugged it with a sheet metal screw and rubber washer. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 13, 2015 Report Share Posted November 13, 2015 Backup petcock! On 11/13/2015 at 12:34 AM, macbwt said: And here i drilled a hole and drained it then plugged it with a sheet metal screw and rubber washer. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted November 15, 2015 Report Share Posted November 15, 2015 Dissimilar metals? 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted November 15, 2015 Report Share Posted November 15, 2015 (edited) I did not do that. I was joking. I know I am a bull in a china shop at times, but I do not believe in those type of repairs. However if the situation was being stranded and my only way to get out of it.......you do what you have to do. On 11/15/2015 at 12:42 AM, enigma-2 said: Dissimilar metals? Edited November 15, 2015 by macbwt Quote Link to comment Share on other sites More sharing options...
mcali6301 Posted November 17, 2015 Author Report Share Posted November 17, 2015 On 11/12/2015 at 11:15 PM, WWWPerfA_ZN0W said: Wait ... there's a problem other than the meandering one??? J/K! Yes, there is a radiator drain plug, located at the bottom driverside of the unit. Part 8115 in the attached PDF diagram. 2011 ford edge radiator drain plug location.PDF Meandering.. LOL....That issue is closed for now. I'll update the case with the details. I went under the car and can barely see the petcock, the ground effects on the sport also help to hide it. I think I'll just pay for the coolant flush. haha. Reason I asked, the coolant level hovers around the lower mark just after getting home from work and the engine is still hot. Also, the coolant res has some brown residue around the inside higher up inside and the coolant is green (I keep reading that the gold coolant should be used) Quote Link to comment Share on other sites More sharing options...
akirby Posted November 17, 2015 Report Share Posted November 17, 2015 On 11/15/2015 at 12:21 PM, macbwt said: I did not do that. I was joking. I know I am a bull in a china shop at times, but I do not believe in those type of repairs. However if the situation was being stranded and my only way to get out of it.......you do what you have to do. When my older brother worked at a local family owned furniture store the delivery pickup (76 F100) sprung a leak in a radiator hose out in the country (this was in rural south Georgia). Sofas used to ship with big rubber bands to hold up the skirt around the bottom so there were always a dozen or so lying on the dash. They were able to wrap a couple of those rubber bands around the hose enough to hold water until they got back to town. The owner (who was also the father of my brother's delivery companion) looked at it and said "I think that will hold for awhile." He was a bit stingy to say the least. My brother and his son said umm...no we're going to get a new hose. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 17, 2015 Report Share Posted November 17, 2015 Does sound like there is crud builtup inside the cooling system, so a flush is a good idea. What worries me more is the possibility of a leak somewhere in the system, which from empirical evidence, happens due to a leaking water pump or porous engine block. There are 3 types of coolant specified for the 2011 model year: •Motorcraft Specialty Green Engine Coolant (dark green-colored)•Motorcraft Specialty Orange Engine Coolant (US)•Motorcraft Specialty Orange Engine Coolant (Canada)2 Whatever the cap on the degas/overflow bottle says is what should be used. These products are NOT interchangeable. Was your Edge built prior to 7/11/2011? Motorcraft Coolant Chart https://www.fcsdchemicalsandlubricants.com/Main/quickref/coolantsEN.pdf Motorcraft Coolant Application Guide.pdfFetching info... On 11/17/2015 at 5:53 PM, mcali6301 said: Reason I asked, the coolant level hovers around the lower mark just after getting home from work and the engine is still hot. Also, the coolant res has some brown residue around the inside higher up inside and the coolant is green (I keep reading that the gold coolant should be used) 2 Quote Link to comment Share on other sites More sharing options...
Fisherman-1947 Posted April 7, 2021 Report Share Posted April 7, 2021 There is no radiator cap on my 2011 3.5L AWD Edge. How do I fill the radiator after draining it? Quote Link to comment Share on other sites More sharing options...
Don Mulvey Posted April 26, 2022 Report Share Posted April 26, 2022 Can't find any info about coolant drains on the 3.5L engine block. Thought I'd post to this thread to see if anyone has looked and knows if a drain exists. Just about to change coolant on my 2015 V6. If there are no replies I'll post back here what I find on my Edge when I get under it. I finished up my 5L F150 and was surprised to discover ... no engine block drain. I don't understand why. Can't be that much cheaper to eliminate the block drain. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 28, 2022 Report Share Posted April 28, 2022 drain is at the radiator https://drive.google.com/file/d/1yb7iiEEb6lynAz24D2PUJEpqqMtTYSWE/view?usp=sharing Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 29, 2022 Report Share Posted April 29, 2022 This PDF procedure does NOT aplly to your 2011, but its official Ford/Lincoln and might offer some insight on a full flush when changing from one coolant to another. (Can't hurt to read). 2009 MKX Cooling System Corrosion.pdf Quote Link to comment Share on other sites More sharing options...
Don Mulvey Posted April 29, 2022 Report Share Posted April 29, 2022 On 4/28/2022 at 10:29 AM, WWWPerfA_ZN0W said: drain is at the radiator https://drive.google.com/file/d/1yb7iiEEb6lynAz24D2PUJEpqqMtTYSWE/view?usp=sharing Expand No, I am looking for block drains. But thanks. Quote Link to comment Share on other sites More sharing options...
