Backing up, very noisy
Sergepaul
Welcome Sergepaul! Do you mean the Titanium? AWD or FWD? Sounds very much like a transmission (clutch) or PTU problem. I would have said possibly brakes if the symptoms appeared even in Drive mode. When you put it in reverse, are you on flat ground, or on a slope (uphill/downhill)? Does this happen even after the car has been driven for a while or only right after when you first start it up for the day?
EDIT: If it's trans related, could be as simple as a shift linkage adjustment. Any difference if switching from Neutral to Reverse versus Park to Reverse (all while the Edge is motionless of course) then moving?
Edited by WWWPerfA_ZN0W
  • Thanks 1
Yes it's the Titanium AWD. I am on flat ground when in reverse and the noise is there even after I have driven it for awhile. Hopefully, it will be a small ajustement in the shift linkage. No difference in the noise from drive to reverse or park to reverse. I will be getting it checked at the beginning of next week.
Thank you for your comments.
  • Thanks 1
  • 3 years later...
Expand
Did you figure out the problem?
