Kazz Posted November 10, 2015 Report Share Posted November 10, 2015 I just bought a 2013 Edge limited. It did not come with HID's. Since this is a Canadian car the DRL's are located in the headlights. Does anyone know if HID's are capable of running DRL's thru them? I went to drivebright site and found some great HID kits with LED strips that he uses for DRL's. My question is can I move the DRL's from the headlights to the strip lights? I have read a post where someone had the dealer can program DRL's to either headlight or strip light. Anyone confirm this? Quote Link to comment Share on other sites More sharing options...
Vadimus Posted November 10, 2015 Report Share Posted November 10, 2015 I programmed DRLs on neighbor's 2009 Edge changing them from headlights to turn bulbs, so basically any dealership with IDS can do it. HIDs directly powered from reduced power/PWM DRL voltage will flicker. Quote Link to comment Share on other sites More sharing options...
benoborich Posted November 11, 2015 Report Share Posted November 11, 2015 I programmed DRLs on neighbor's 2009 Edge changing them from headlights to turn bulbs, so basically any dealership with IDS can do it. HIDs directly powered from reduced power/PWM DRL voltage will flicker. Doesn't that defeat the purpose of DRL's, that being to increase safety by making your vehicle more visible on the road? Quote Link to comment Share on other sites More sharing options...
Vadimus Posted November 11, 2015 Report Share Posted November 11, 2015 (edited) Turn bulbs provide some extra visibility as well. There is no regulated amount of light that DRLs need to provide I am aware of, and some stock DRL setups are considerably less bright than this 2 turn signal kind. My personal opinion is that low beams as DRLs should be prohibited at all - they give bad drivers a dangerous illusion that their headlights (and tail lights too!) are on, especially with modern always-lit instrument clusters. Edited November 11, 2015 by Vadimus Quote Link to comment Share on other sites More sharing options...
MC11_13 Posted November 11, 2015 Report Share Posted November 11, 2015 Yes, you can attach HIDs, are you in Canada? reason i ask is that i can get good HID kits cheap. Quote Link to comment Share on other sites More sharing options...
MC11_13 Posted November 11, 2015 Report Share Posted November 11, 2015 Turn bulbs provide some extra visibility as well. There is no regulated amount of light that DRLs need to provide I am aware of, and some stock DRL setups are considerably less bright than this 2 turn signal kind. My personal opinion is that low beams as DRLs should be prohibited at all - they give bad drivers a dangerous illusion that their headlight (and tail lights too!) are on, especially with modern always-lit instrument clusters. Actually, if it is a projector headlight, then no. if it has the cup over the light like most standard headlights, then yes HIDs will give you a really bad glare. Quote Link to comment Share on other sites More sharing options...
Vadimus Posted November 11, 2015 Report Share Posted November 11, 2015 HIDs retrofitted in a reflector headlight is a very bad thing. You will blind other drivers no matter what. Just because of optics laws. A while back I had 9006 HID kit on my 2005 Ford Freestyle and I still feel the shame for being careless. In halogen projector headlights HIDs are somewhat acceptable. Quote Link to comment Share on other sites More sharing options...
Kazz Posted November 12, 2015 Author Report Share Posted November 12, 2015 (edited) HIDs retrofitted in a reflector headlight is a very bad thing. You will blind other drivers no matter what. Just because of optics laws. A while back I had 9006 HID kit on my 2005 Ford Freestyle and I still feel the shame for being careless. In halogen projector headlights HIDs are somewhat acceptable. Vadimus, I checked the part numbers and the factory headlight assembly is the same wether you have factory HID's or not. The olny difference I see is the bulb itself and of course the ballasts. I guess I have to ask is the edge's headlight assembly a reflector headlight? Edited November 12, 2015 by Kazz Quote Link to comment Share on other sites More sharing options...
Vadimus Posted November 12, 2015 Report Share Posted November 12, 2015 (edited) Vadimus, I checked the part numbers and the factory headlight assembly is the same wether you have factory HID's or not. The olny difference I see is the bulb itself and of course the ballasts. I guess I have to ask is the edge's headlight assembly a reflector headlight? I believe first version of Edge did not have either lens or HID options. Edited November 12, 2015 by Vadimus Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 12, 2015 Report Share Posted November 12, 2015 Only factory halogens in reflector (non-projector) housings for high/low beams. Not sure if the fogs qualify as projectors though. Aftermarket projector headlight assemblies are available. I believe first version of Edge did not have either lens or HID options. 1 Quote Link to comment Share on other sites More sharing options...
Kazz Posted November 12, 2015 Author Report Share Posted November 12, 2015 Only factory halogens in reflector (non-projector) housings for high/low beams. Not sure if the fogs qualify as projectors though. Aftermarket projector headlight assemblies are available. That makes sense as when I search for aftermarket HID kits like from drivebright there is no mention of issues. Just a plug and play. Quote Link to comment Share on other sites More sharing options...
normcloutier Posted November 13, 2015 Report Share Posted November 13, 2015 If you want to install HID in your 13 SEL, ask your dealer to change the DRL from headlights to parking lamps. This way your HID lamps won't be on all the time. Plus the lower voltage to the headlights while in DRL mode will be eliminated. I had this done on mine. Took 5 minutes. I then installed a HID kit. Big improvement. Quote Link to comment Share on other sites More sharing options...
Kazz Posted November 13, 2015 Author Report Share Posted November 13, 2015 If you want to install HID in your 13 SEL, ask your dealer to change the DRL from headlights to parking lamps. This way your HID lamps won't be on all the time. Plus the lower voltage to the headlights while in DRL mode will be eliminated. I had this done on mine. Took 5 minutes. I then installed a HID kit. Big improvement. Thanks Normcloutier. I have a limited but would think the DRL's set up is the same. Quote Link to comment Share on other sites More sharing options...
