Dim Headlights on 2011 FOrd Edge
I noticed after the summer that the headlights on our 2011 Ford Edge are dim.
I have never experienced something like this on another car. Granted, at some point the bulb will go out, but not dim.
Has anyone else experienced something like this?
When I look into the lens it almost seems that there is a film of dirt inside (behind the round bubble) - not water condensation.
Dealer is not much help...
Looks like some other folks had simialr issues. However, fromt his thread I woudl assume they had the issue from the factory;
http://www.fordedgeforum.com/topic/10977-headlights-in-my-2013-edge/page-3
I do think the light was better when new. I had to spend money for a HID upgrade or similar to get at least basic average light output. To me this is a safety issue.
  On 11/21/2015 at 5:57 PM, trockli said:
That bulb appears to be the same as the original bulb that I pulled. I think it is as good as any standard bulb.
At this point I do not think the problem is the bulb, rather a lens quality issue.
Does the stock bulbs have the Philips logo on them?
Just because it looks like the same bulb does not mean that it performs the same.
I will take a look at my stock bulbs and see if it is made by Philips or not.
I think that my Edge has plenty of light for a non-HID equipped car hence why I have not changed the factory bulbs out.
I would like to find a HID-look replacement bulb, but most are blue flim-tinted 9012 bulbs that are cheaply made which are dimmer than the stock bulbs from what I have researched.
The Philips bulbs seem to be the only real upgrade for brighter output for 9012 bulb equipped cars from what I researched without using a HID kit.
Edited by carguy75
Well, Philips have made about 3 generations of the 9012 bulb, so I do not know if we have the best version equipped as OEM in our Edges compared to the retail bulbs available in the stores.
My Edge is a 2011 model so I bet that I do not have the latest version of the 9012 bulb installed, however with that being said I do not have a problem with the brightnest of my headlights.
Just the yellowish color of the light.
Maybe you should just polish your lenses and see if it helps.
Yes, I just do not know how to. Again, the outside lense is clean, not cracked,.. It is the inside round lens that seems to have a film like resedue. Possibly on the inside. But I don't see a way to clean it. Would need tobe through the small opening after the bub is removed?
