jstall7543 Posted October 30, 2015 Report Share Posted October 30, 2015 I was looking for a good easy spot to run 4 gage wire thru the firewall on 2013 edge sport. I need a little more bass than the factory sub can deliver! Any suggestions would be greatly apreciated! Quote Link to comment Share on other sites More sharing options...
kkreit01 Posted October 31, 2015 Report Share Posted October 31, 2015 It's not easy. It was the worst ever for me. It took me about 2 hrs. About the only location to get it through, is by the OE harness -- where all the other wiring goes through. I alaways paranoid of cutting here, because I'm afraid I'll cut some OE wires. I started small, and couldn't get it through. I finally got brave, and used a larger serrated knife, and of course always have the blade facing away from all wiring. I then taped my 4ga Knu cable to a stiff hanger, and fished it through. There's not much space in the engine compartment to grab it. I thought I might have to pull the battery, but I managed. My cable was real flexible, which made it more difficult. Good luck. Someone said there's a spot on the passengers side, but I didn't want to run my cable across the engine, inside the bay. Quote Link to comment Share on other sites More sharing options...
jstall7543 Posted October 31, 2015 Author Report Share Posted October 31, 2015 Dang! It does look a little scary under there! Are you saying to go thru behind the big wire bundle plugs near the center? Could I talk you out of a pic? Quote Link to comment Share on other sites More sharing options...
normcloutier Posted October 31, 2015 Report Share Posted October 31, 2015 I ran some cables through the existing grommet behind the battery on my 13 SEL. There is an extra unused port (like a rubber nipple) you can snip and pull cable through. Quote Link to comment Share on other sites More sharing options...
jstall7543 Posted October 31, 2015 Author Report Share Posted October 31, 2015 Nice! Thank You! Quote Link to comment Share on other sites More sharing options...
snake456 Posted October 31, 2015 Report Share Posted October 31, 2015 The grommet Norm is talking about is the perfect place. I have used it also. Quote Link to comment Share on other sites More sharing options...
jstall7543 Posted November 3, 2015 Author Report Share Posted November 3, 2015 Thanks for the info guys! Quote Link to comment Share on other sites More sharing options...
kkreit01 Posted November 11, 2015 Report Share Posted November 11, 2015 I was going to use that as well, but I would have had to pull the battery to snip it. Also, my 4ga Knu cable was quite thick (large jacket). In hindsight, I should have just pulled the battery. Quote Link to comment Share on other sites More sharing options...
jstall7543 Posted November 11, 2015 Author Report Share Posted November 11, 2015 What happens when you re-connect the battery? Do I need a code or anything for 13 edge sport sony system? Quote Link to comment Share on other sites More sharing options...
kkreit01 Posted November 21, 2015 Report Share Posted November 21, 2015 You shouldn't need a code. Batteries die every day, and have to be replaced. Some newer Chryslers will ask for one, but they will be fune once the vehicle is started. Quote Link to comment Share on other sites More sharing options...
