Gordon 2135 Posted October 24, 2015 Report Share Posted October 24, 2015 Hi, am new to the forum. I just purchased a 2010 Ford Edge and have noticed that when only on the highway, speeds over 60 and after I have been on the road for about 40 miles I am hearing a loud humming. This seems to come and go as far as driving straight forward. It gets more noticeable when turning to the right, turning off the ramp...If I turn left the noise goes away. In town, slower speeds, never hear it. Can this be a wheel bearing? or maybe a CV joint? Car has 94,000. Unsure of the history as far as repairs/replacements. Thanks in advance for anyone that can point me in the right direction. Gordon Quote Link to comment Share on other sites More sharing options...
macbwt Posted October 24, 2015 Report Share Posted October 24, 2015 Yep, and bet it is the right rear wheel bearing. Now all you need to do is verify which wheel it is and then replace it. Note: I say right rear because for some reason those are usually the first to go on the Edge. Then the right front after that. At least that is how it worked out for me. I replace a total of 6 wheel bearings in just under 300k miles on the Orange Crush. Quote Link to comment Share on other sites More sharing options...
Gordon 2135 Posted October 24, 2015 Author Report Share Posted October 24, 2015 Rear? really...It sounds like it is coming from the front and consistant with turning right and goes away when turning left. Can the Ford dealership tell before replacing which one it is? I bought the car used, have a Monday appointment and my 30 days runs out the 1st of Nov. Thanks for your thoughts, everyone looks at things differently. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted October 25, 2015 Report Share Posted October 25, 2015 If it were me, I would also ask to have ALL fluid levels checked, including to differentials and transaxle. 2 Quote Link to comment Share on other sites More sharing options...
macbwt Posted October 25, 2015 Report Share Posted October 25, 2015 (edited) Keep in mind I was just betting on which one was bad not knowing where the noise was coming from. Law of averages. If the noise seems to be from the front then it very well may be. Sometimes it can trick you as the noise can travel and appear to be from one area and actually be another issue in a different location. I bet the interior air filter in the glove box has not been changed and is completely clogged. I doubt the power steering has fluid has been changed, transmission fluid, brake fluid etc. Most dealers only change the engine oil and leave the rest to you. When I buy a used vehicle I change all fluids as soon as I can. Edited October 25, 2015 by macbwt 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted October 25, 2015 Report Share Posted October 25, 2015 The transmission fluid change was done on my 2011 with just about the same miles as your 2010. Might want to do this also. 1 Quote Link to comment Share on other sites More sharing options...
Gordon 2135 Posted October 26, 2015 Author Report Share Posted October 26, 2015 Macbwt....yup you were dead on. Right rear it was. Thanks for the info, got it taken care of today. The Ford dealership wanted $350. I purchased an OEM for $130 and paid my repair shop $90 to install it, so saved $220. Fluids, good point. The dealer changed the oil and tranny fluids, and it's obvious in the color. Next is get the rear and transaxles done. Thanks to all that put me in the right direction, I find this forum interesting reading, and a plus to maintaining my new ride. I did also purchase a cabin filter, inexpensive, and easy to change. 2 Quote Link to comment Share on other sites More sharing options...
macbwt Posted October 27, 2015 Report Share Posted October 27, 2015 (edited) Could you please tell my wife this!!! LOL Glad you got it repaired. Don't forget the power steering fluid. HA HA you might want to check your math on the savings but I get that you saved about 130.00 Macbwt....yup you were dead on. Right rear it was. Thanks for the info, got it taken care of today. The Ford dealership wanted $350. I purchased an OEM for $130 and paid my repair shop $90 to install it, so saved $220. Fluids, good point. The dealer changed the oil and tranny fluids, and it's obvious in the color. Next is get the rear and transaxles done. Thanks to all that put me in the right direction, I find this forum interesting reading, and a plus to maintaining my new ride. I did also purchase a cabin filter, inexpensive, and easy to change. Edited October 27, 2015 by macbwt 1 Quote Link to comment Share on other sites More sharing options...
Gordon 2135 Posted October 27, 2015 Author Report Share Posted October 27, 2015 Whoops....I just noticed that! So checked the p/s fluid to find it a little low, swapped it out with some fresh mercon lv. Good 2 go for the winter coming in soon. Again, thanks for every ones help. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 27, 2015 Report Share Posted October 27, 2015 I really hope you didn't put the LV fluid in the power steering reservoir. For the 2010: Transmission Fluid: Mercon LV Power Steering Fluid: Mercon V Does the reservoir cap say to put in Mercon LV for power steering, by any chance? Quote Link to comment Share on other sites More sharing options...
Gordon 2135 Posted October 28, 2015 Author Report Share Posted October 28, 2015 Looks like I need to do the flush again....the video you sent me shows a 2011, who would think one year difference, same model, same engine would be a different version of the same mercon fluid used in the transmission. In the video you sent me, it shows LV being used. I talked to the Ford dealer, said it shouldn't be a problem. So my bad to use the video sent, I should have compared, done a little more homework before I purchased the LV. I have not put more than 10 miles or so on the vehicle, so on my way to p/u some V..... I see no UTube videos showing the 2010 change out. Quote Link to comment Share on other sites More sharing options...
akirby Posted October 28, 2015 Report Share Posted October 28, 2015 Looks like I need to do the flush again....the video you sent me shows a 2011, who would think one year difference, same model, same engine would be a different version of the same mercon fluid used in the transmission. In the video you sent me, it shows LV being used. I talked to the Ford dealer, said it shouldn't be a problem. So my bad to use the video sent, I should have compared, done a little more homework before I purchased the LV. I have not put more than 10 miles or so on the vehicle, so on my way to p/u some V..... I see no UTube videos showing the 2010 change out. The fluid specs are very clearly spelled out in the owner's manual - always go by that. Even within the same model year there can be changes. Quote Link to comment Share on other sites More sharing options...
Gordon 2135 Posted October 28, 2015 Author Report Share Posted October 28, 2015 (edited) Yup read the manuel.....after OKKK Got the LV out and V in, did five times, seems fine on the road. Lesson learned. Edited October 28, 2015 by Gordon 2135 2 Quote Link to comment Share on other sites More sharing options...
macbwt Posted October 29, 2015 Report Share Posted October 29, 2015 Sorry about that. But hey you got er changed out now and no worries. Always read the cap and RTB! Yup read the manuel.....after OKKK Got the LV out and V in, did five times, seems fine on the road. Lesson learned. Quote Link to comment Share on other sites More sharing options...
