headlamp problem
  • 2 months later...
There is no hi beam/low beam. It's a single lamp with a shutter that cuts off the top of the light for low beam. Activating high beam just moves the shutter so the light shines higher..
My error. On my Lincoln, I believe that they are separate lights. I've never noticed any shutter. Thanks for the explanation. Edited by enigma-2
The dark spot I had was in the middle of the beams in the front. However, after going to a local shop at work, they were working on a late model SUV interceptor. Showed me about laying down the front facade, doing so I removed the headlight and found that my bulbs were not in properly. One of the ears on the edge of the bulb was not in the guide. I miss the old fashioned plastic ones you can see!
