GStam66 Posted October 18, 2015 Report Share Posted October 18, 2015 Hey everyone! I just bought a used 2010 Edge Limited about a week ago, and I need some help regarding the Sync and using a USB for music (didn't come with a manual and searching didn't turn up any concrete answers). Whenever I turn the car on it automatically syncs to my phone, which is fine and all, but it also automatically plays the music on it. I have a USB with about 550 songs on it that I want to be the default music source. I plugged it in yet the car won't recognize it, it's not even an option via the menu. They're all mp3's and the files are all valid. I'm not sure if there's some weird limit on how big of a folder the system can read (had to limit folders to 100 songs each on an older Kenwood receiver I had in another car)? Basically what I want to do is have the car play the music from the USB by default, but still be synced to my phone for calls. How can I make that happen? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
omar302 Posted October 18, 2015 Report Share Posted October 18, 2015 Make sure the USB is formatted to Fat32 (as far as I remember). Also, try first with a few songs before putting so many. For the manual, PDF copies are available online, including the manual for Sync. Finally, make sure you have latest updates for sync at http://www.syncmyride.com/ 1 Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted October 18, 2015 Report Share Posted October 18, 2015 1, you need to turn off "auto play" this will prevent your bluetooth from play automatically.2, as stated, make sure your USB is formatted to fat32. I have a 500GB external hard drive hooked up to my car. Only has 10,000mp3s on it 1 Quote Link to comment Share on other sites More sharing options...
GStam66 Posted October 18, 2015 Author Report Share Posted October 18, 2015 Got it, thank you. I'll try to find the manual to see how to shut off the autoplay. the USB is formatted as Fat32. Do you have all the songs in one folder? or are they split up among multiple folders? Quote Link to comment Share on other sites More sharing options...
GStam66 Posted October 18, 2015 Author Report Share Posted October 18, 2015 Update: I just unchecked the "audio streaming" option on the phone. Right when the phone wasn't playing THEN it recognized the USB. Everything seems to be working so far. Thank you again! Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted October 19, 2015 Report Share Posted October 19, 2015 they are in tons of folders and highly unsorted. I have OCD so it drives me nuts! Quote Link to comment Share on other sites More sharing options...
fe2102 Posted January 6, 2016 Report Share Posted January 6, 2016 Hi Gstam, I'm running into similar problem as yours. The usb flash I had in was working for about 2 weeks and then one day its no longer working. I only have like 12 songs on a 2 Gig flash drive and I know its formatted as FAT32. All I see on display is "sync line in" when i insert the usb and thats it. It used to play the song automatically and show the name of song while playing it but not anymore! Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted January 7, 2016 Report Share Posted January 7, 2016 Hi Gstam, I'm running into similar problem as yours. The usb flash I had in was working for about 2 weeks and then one day its no longer working. I only have like 12 songs on a 2 Gig flash drive and I know its formatted as FAT32. All I see on display is "sync line in" when i insert the usb and thats it. It used to play the song automatically and show the name of song while playing it but not anymore! try unhooking the battery and plug it back in. seems to solve a lot of sync issues Quote Link to comment Share on other sites More sharing options...
FordIVTteam Posted January 7, 2016 Report Share Posted January 7, 2016 Hi Gstam, I'm running into similar problem as yours. The usb flash I had in was working for about 2 weeks and then one day its no longer working. I only have like 12 songs on a 2 Gig flash drive and I know its formatted as FAT32. All I see on display is "sync line in" when i insert the usb and thats it. It used to play the song automatically and show the name of song while playing it but not anymore! Hi fe2102, Are you able to change the music source manually? When you see SYNC LINE IN, select MENU>SELECT SOURCE>USB. Let me know if this works. Shaay Quote Link to comment Share on other sites More sharing options...
fe2102 Posted January 8, 2016 Report Share Posted January 8, 2016 Hi fe2102, Are you able to change the music source manually? When you see SYNC LINE IN, select MENU>SELECT SOURCE>USB. Let me know if this works. Shaay Hi Shaay, Thanks for the response. First let me say that mine is only the base model (SE) and I dont recall seeing source after selecting menu. I dont think I have the voice activated sync either but I will try doing what Nick said and let you know. Thanks again. Quote Link to comment Share on other sites More sharing options...
FordIVTteam Posted January 8, 2016 Report Share Posted January 8, 2016 (edited) Hi Shaay, Thanks for the response. First let me say that mine is only the base model (SE) and I dont recall seeing source after selecting menu. I dont think I have the voice activated sync either but I will try doing what Nick said and let you know. Thanks again. The instructions I provided is for the basic SYNC system. You have to use the ARROW key or VOLUME knob to scroll to SELECT SOURCE. If this does not work, I recommend trying a master reset: http://owner.ford.com/sync-technology/perform-master-reset-sync I don't suggest removing the battery without consulting with your dealer. Shaay Edited July 18, 2016 by FordIVTteam Quote Link to comment Share on other sites More sharing options...
fit1446 Posted January 8, 2016 Report Share Posted January 8, 2016 (edited) Hi Gstam, I'm running into similar problem as yours. The usb flash I had in was working for about 2 weeks and then one day its no longer working. I only have like 12 songs on a 2 Gig flash drive and I know its formatted as FAT32. All I see on display is "sync line in" when i insert the usb and thats it. It used to play the song automatically and show the name of song while playing it but not anymore! :try doing a master reset..what version of sync do u have gen 1 v 4.4? Edited January 8, 2016 by fit1446 Quote Link to comment Share on other sites More sharing options...
fe2102 Posted January 8, 2016 Report Share Posted January 8, 2016 The instructions I provided is for the basic SYNC system. You have to use the ARROW key or VOLUME knob to scroll to SELECT SOURCE. If this does not work, I recommend trying a master reset: http://owner.ford.com/sync-technology/perform-master-reset-sync Idon't suggest removing the battery without consulting with your dealer. Shaay Ok I just did what Nick said and after reconnecting the battery I then saw the option "source". I dont remember seeing that before battery disconnection. Anyway Its working now and I'm very happy Thanks guys you're awesome! Specially you Shaay. 1 Quote Link to comment Share on other sites More sharing options...
FordIVTteam Posted January 9, 2016 Report Share Posted January 9, 2016 Ok I just did what Nick said and after reconnecting the battery I then saw the option "source". I dont remember seeing that before battery disconnection. Anyway Its working now and I'm very happy Thanks guys you're awesome! Specially you Shaay. You're welcome! I'll be here if anything else comes up. Shaay Quote Link to comment Share on other sites More sharing options...
fit1446 Posted January 10, 2016 Report Share Posted January 10, 2016 You're welcome! I'll be here if anything else comes up. Shaay Shaay you are so smart!! Quote Link to comment Share on other sites More sharing options...
FordIVTteam Posted January 11, 2016 Report Share Posted January 11, 2016 Shaay you are so smart!! fit1446, Thanks! Shaay Quote Link to comment Share on other sites More sharing options...
fe2102 Posted July 15, 2016 Report Share Posted July 15, 2016 You're welcome! I'll be here if anything else comes up. Shaay Hello Shaay, I hope you read this but I have run into same problem again! After I press the menue button, the option "source" is not there! very strange indeed. In fact even after I take the usp stick out, a message says usb disconnected but still shows sync line in and none of the arrow keys do anything. Quote Link to comment Share on other sites More sharing options...
FordIVTteam Posted July 18, 2016 Report Share Posted July 18, 2016 Hi fe2102, Thanks for reaching out! Have you tried the master reset? Shaay Quote Link to comment Share on other sites More sharing options...
fe2102 Posted July 22, 2016 Report Share Posted July 22, 2016 I have no idea how to do that. But why would this happen every once in a while? Quote Link to comment Share on other sites More sharing options...
FordIVTteam Posted July 23, 2016 Report Share Posted July 23, 2016 (edited) I have no idea how to do that. But why would this happen every once in a while? Hi fe2102, I can't say why this has been happening, but you can find the reset steps here: https://owner.ford.com/how-tos/sync-technology/sync/phone-setup/how-to-perform-a-master-reset.html?sync=sync Cara Edited July 23, 2016 by FordIVTteam Quote Link to comment Share on other sites More sharing options...
fe2102 Posted July 24, 2016 Report Share Posted July 24, 2016 I checked out that linked but both directions first step says about connectivity of phone? I dont have any phone connected to the sync system so that threw me off and I'm not sure what to do from there! Quote Link to comment Share on other sites More sharing options...
FordIVTteam Posted July 25, 2016 Report Share Posted July 25, 2016 (edited) Hey fe2102, Step #1 is needed if you have a phone connected to SYNC. You can skip to step #2: On the SYNC screen, press the MENU button. Press the DOWN ARROW button until SYNC SETTINGS displays on the screen then select OK. Press the DOWN ARROW button until MASTER REST displays on the screen then select OK. A confirmation message displays on the screen; press YES. I hope this helps! Shaay Edited July 25, 2016 by FordIVTteam Quote Link to comment Share on other sites More sharing options...
fe2102 Posted July 26, 2016 Report Share Posted July 26, 2016 Shaay when I press Menu I only have these 4 options; Sync-Media Audio Settings Clock Settings Display Settings. There is no option such as Sync Settings! Quote Link to comment Share on other sites More sharing options...
akirby Posted July 26, 2016 Report Share Posted July 26, 2016 Did you try pressing the down arrow as instructed? The menu may scroll. Quote Link to comment Share on other sites More sharing options...
fe2102 Posted July 26, 2016 Report Share Posted July 26, 2016 Did you try pressing the down arrow as instructed? The menu may scroll. Hi akirby, Thanks for responding. Yes I did scroll down with that arrow down button and nothing other than those 4 options I said before. Quote Link to comment Share on other sites More sharing options...
