Passenger mirror
Ibewsparky
Probably have to remove the glass then depress tabs to release the mirror cover (if it is like the 2007):
Exterior Mirror Glass
Removal
  1. Position the exterior mirror glass in a downward position to obtain a gap at the top edge of the mirror.
  1. WARNING: Place a shop towel between the exterior mirror glass and the hand to avoid personal injury in case of glass breakage.
    Disengage the mirror glass.
    • Insert a flat-blade screwdriver between the mirror glass tabs and the mounting plate and rotate to separate the locking tabs from the mounting plate.
    • Continue to insert and rotate the screwdriver until the remaining mirror glass tabs separate from the mounting plate.
    • Carefully pull the top edge of the glass away from the exterior mirror housing.
  2. If equipped, disconnect the heated mirror and auto-dimming electrical connectors and remove the glass.
Exterior Mirror Cover
  1. Remove the exterior mirror glass. For additional information, refer to Exterior Mirror Glass in this section.
  1. Depress the 4 tabs and remove the exterior mirror cover.
