DunePearlEdge Posted October 6, 2015 Report Share Posted October 6, 2015 Does the TPS need to be replaced when getting new tires? My sensors are at least 50k miles and 4 years old. Is the sensor typically replaced or just the battery? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 6, 2015 Report Share Posted October 6, 2015 The battery is integral to the sensor, so you'd have to replace the sensor. A tire shop can tell you if they expect the sensors have enough life left. But the typical life of the battery is between 5-7 years. I didn't have them replaced on my Edge when I recently had the tires done, will see what happens At worst they will have to dismount the tires and put in new sensors! Quote Link to comment Share on other sites More sharing options...
macbwt Posted October 7, 2015 Report Share Posted October 7, 2015 Good thing I traded my orange crush. Putting new TPMS sensors in would have been the final straw. Quote Link to comment Share on other sites More sharing options...
boosted edge Posted October 7, 2015 Report Share Posted October 7, 2015 My 2008 Edge has 138000 miles on it. I am getting ready for the fourth set of tires on it, and the TPMS are the originals and are working fine! I do want a 2016 Edge before that time, hopefully! Quote Link to comment Share on other sites More sharing options...
DunePearlEdge Posted October 7, 2015 Author Report Share Posted October 7, 2015 It sounds like they last longer than I expected. I called local tire shops and they charge $60-80 per wheel for new units as the battery is integrated. Are the units on a 2007 band type or the air inlet type? Quote Link to comment Share on other sites More sharing options...
macbwt Posted October 8, 2015 Report Share Posted October 8, 2015 I am guessing mileage has no effect on them because I never had an issue on my 2008. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 8, 2015 Report Share Posted October 8, 2015 Band type. I think the stem type went into production in 2011, MAYBE 2010. As long as the manufacturer warrants it for the year/model, it doesn't really matter. It sounds like they last longer than I expected. I called local tire shops and they charge $60-80 per wheel for new units as the battery is integrated. Are the units on a 2007 band type or the air inlet type? Quote Link to comment Share on other sites More sharing options...
Waldo Posted October 8, 2015 Report Share Posted October 8, 2015 TPMS sensors only send out signals once every 2 minutes, not continuously, so the batteries will last a long time. Quote Link to comment Share on other sites More sharing options...
macbwt Posted October 8, 2015 Report Share Posted October 8, 2015 (edited) I can confirm in my last video that they are attached to the valve stems for the 2011 and most likely up. Band type. I think the stem type went into production in 2011, MAYBE 2010. As long as the manufacturer warrants it for the year/model, it doesn't really matter. Edited October 8, 2015 by macbwt 1 Quote Link to comment Share on other sites More sharing options...
