SlickBlueEdge Posted October 2, 2015 Report Share Posted October 2, 2015 For the life of me I cannot find the firing order? I've got a cylinder 4 misfire, injector 4 malfunction. I bought the injector, but what cylinder is #4??? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 3, 2015 Report Share Posted October 3, 2015 Firewall side of engine (passengerside to driverside) 1,2,3 Radiator side of engine (passengerside to driverside) 4,5,6 So #4 would be the the leftmost cylinder of the 3 visible to you, right next to the oil fill cap. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 3, 2015 Report Share Posted October 3, 2015 Might want to run a couple of tanks of BG 44K or Techron concentrate through to see if that helps fix anything first. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted October 4, 2015 Report Share Posted October 4, 2015 Well I never....exposing your topless engine to the public.... Firewall side of engine (passengerside to driverside) 1,2,3 Radiator side of engine (passengerside to driverside) 4,5,6 So #4 would be the the leftmost cylinder of the 3 visible to you, right next to the oil fill cap. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 4, 2015 Report Share Posted October 4, 2015 That's how we roll ... defiant and bold Quote Link to comment Share on other sites More sharing options...
SlickBlueEdge Posted October 6, 2015 Author Report Share Posted October 6, 2015 You guys are awesome! Thank you! I ran some Lucas injector cleaner through it, didn't seem to help. Any other products to try before I can't return the injector? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 6, 2015 Report Share Posted October 6, 2015 Swap the #4 coil with #5 or #6, see if the misfire moves with it. With any luck it may be just a coil. Could be a spark plug issue as well if they are original to your Edge. If the coil is not it, then pull the plugs and check the gaps. Try Techron Concentrate or BG 44K, two of the top cleaners in the industry. Proceed straight to GO with these cleaners, don't bother with anything else. Quote Link to comment Share on other sites More sharing options...
rickwhoo Posted September 12, 2019 Report Share Posted September 12, 2019 I'm discussing this with a garage owner and he says its 135 on the windshield side??? What is the correct side for cyl. 123 Quote Link to comment Share on other sites More sharing options...
