Lights
aliva
I'm new to this forum and have a some questions concerning HID headlights, so please bare with me.
I have a 2014 Edge Limited with standard headlights and am interested in going to HID's.
First, my existing lights are both Hi and Low beam, what king of HID kit would I purchase?.
Secondly how does the HID provide both Hi beam and Low beam with 1 bulb?.
Also I was under the impression that the lamp holder has to be a projector type for each HID bulb. so the light does not scatter, thereby eliminating on coming vehicles from flashing you .My Edge has only 1 projector housing.
I did have a 2009 F150 and wanted to change to HID, but was told I'd have to change the lamp holder to a projector type, which was a very expensive change over.
Do i have to add a second projector housing?
Any answers would be very much appreciated.
Thanks
No. Just get a kit with the right bulb type and plug em in.
You'll have to drill holes in the headlight caps by using a 7/8" spade bit but that's the only thing that you'll have to modify. Brights work just like a normal bulb. I recently installed a used kit from daytimebrightlites.com from another member. And it's basically plug n play. Like I said only thing you'll have to do is modify the caps. Easy peasy.
Edited by jrSS
