Tracy Turner Posted September 21, 2015 Report Share Posted September 21, 2015 This past saturday when pulling out of a parking lot the RPMs dropped and there was no throttle response at all. The dash displayed a poweretrain failure and the gold wrench at the bottom. I shut it off and restarted it. Everything was fine and it drove as normal for a couple miles before doing it again. This time there was no powertrain failure message but the check engine light did come on. It did this a few times before I could get to a safe place. I had it towed home. The code was p2111. The next day the battery was dead (original battery). I charged it and got it started. Later in the day it was dead again. I had the battery tested and it tested bad. After replacing the battery the codes were cleared and it runs and drives fine. I drove it in to work this morning and have had no issues. If the battery was failing could the low voltage situation cause the issues that I experienced? Any help or information would be appreciated. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 21, 2015 Report Share Posted September 21, 2015 (edited) Glad you made it out ok from this situation! p2111 is a throttle body actuator error code. Bad/low battery MIGHT cause it, but have not had anecdotal evidence for that. May be looking at a replacement situation soon. Did anyone besides you document the situation? http://www.explorerforum.com/forums/showthread.php?t=313953 http://www.allfordmustangs.com/forums/2005-2010-mustang-gt-tech/287511-wrench-light-codes-p2111-p2104.html http://highlanderclub.ru/files/manual/04/21j6674h/cip2111.pdf Toyota Highlander OBDII Code p2111.pdf https://www.motorcraftservice.com/vdirs/diagnostics/pdf/OBDSM1105.pdfpg 134 With the installation of a new battery on the 2011+, it is necessary to also reset the Battery Management System (BMS) so that the Edge knows to learn the new battery & charge it correctly. A dealer or a shop with IDS access should be able to do this. Edited September 21, 2015 by WWWPerfA_ZN0W 1 Quote Link to comment Share on other sites More sharing options...
