enigma-2 Posted April 1, 2021 Report Share Posted April 1, 2021 If your concerned about having open holes (abet 1/16" dia), consider drilling larger holes, 1/4" for example, in the back where they don't show, and covering with Gor Tex. The material prevents liquid water entry while allowing water vapor to pass. This could be accomplished with self-adhesive patches that are easy to apply. (The fix is to vent the interior water vapor to the atmosphere. It appears the existing vents are not functioning). https://www.amazon.com/dp/B07WTRDKMP/ref=cm_sw_r_cp_apa_glc_fabc_88PT3ZZ5MJRFTQVYQXZ7 Quote Link to comment Share on other sites More sharing options...
BigBerky Posted April 2, 2021 Report Share Posted April 2, 2021 Thank you 1004 and enigma, I removed the part and found a gap in the seal immediately. Right in the area of the most condensation. Whatever adhesive they use to seal the clear lens to the black plastic back has an inconsistent bead. The bead gets real thin in a section and the 2 halves have separated. I’m thinking about resealing the entire joint all the way around with good RTV silicone. I’m sure this will help but I’m not 100% confident this will solve all condensation issues. We’ll see I guess. If not, I like the idea of a couple added goretex covered vents in the back. There is 2 back there already...why not 4 right? I’ll seal it first and reinstall. Maybe it will vent correctly. I would send it back were I bought it, but it’s not new and I bought it a month ago. I saved $600 over buying a new part. It looks perfect but its not. My advice: BUY NEW PARTS I screwed myself but maybe I can fix this thing. see pic of the gap 5 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 7, 2021 Report Share Posted April 7, 2021 (edited) You may have found the real problem that has plagued dozens of complaints with the Edge. Moisture has to be getting in through a small crack somwhere (if it were larger, the moisture could also escape easily). Lights on raise the temps inside, when shut off, unit cools and creates a small partial vacuum drawing in the cool, moist evening air. I'd clear silicone the hell out of the entire joint. Good find!!! Edited April 7, 2021 by enigma-2 2 Quote Link to comment Share on other sites More sharing options...
BigBerky Posted April 11, 2021 Report Share Posted April 11, 2021 Update: I dried out the condensation with a vacuum and space heater through the access plug in the back. I then ran a thick bead of high quality rtv silicone all the way around where the two halves meet. Let it cure for a couple days. Tested the vent holes in the back with blow drier and they seem to be working. I reseated the access hole plug with some thick silicone grease. This product does not cure and it has a high washout value. The plug is sealed but still able to be removed. The part was reinstalled today and it looks good so far. The part is sealed except for the vent holes. This is the closest I can get to how this part was new. Let’s see if it vents function correctly per Fords design. I did notice a large gap on the top of the unit where the rubber gasket does not make contact with the rear gate under the back glass. See pic. I’ve looked at a few other edges and they all had the same gap. This would appear to be normal? Maybe help the venting process? There is the possibility of water getting behind the light bar through this gap. If the unit still has condensation issues I’m going to fill that gap with silicone to prevent water from running down behind the light bar and making contact with those vents. We’ll see what happens in the rain and car wash. Am I missing anything? Thanks, 1 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted April 11, 2021 Report Share Posted April 11, 2021 Just checked, mine has that gap and don't have an issue in storms or the car wash. Quote Link to comment Share on other sites More sharing options...
BigBerky Posted April 11, 2021 Report Share Posted April 11, 2021 Thanks 1004, I appreciate the quick feedback. Thanks for your input as well. Quote Link to comment Share on other sites More sharing options...
BigBerky Posted April 21, 2021 Report Share Posted April 21, 2021 Update: Over a week with rainy weather and temp swings and the light bar is condensation free. Made it through a high pressure car wash as well. Maybe we have a fix here... fingers crossed. 4 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 22, 2021 Report Share Posted April 22, 2021 With so many people reporting this problem, looks like you may have single-handily found the answer that Ford hasn't been able to answer. Quote Link to comment Share on other sites More sharing options...
wakabal Posted August 25, 2021 Report Share Posted August 25, 2021 2017 Edge just developed this issue. Ford denies claim on extended warranty and wants $1900 to fix. What a bunch of BS. Any help is appreciated. Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 25, 2021 Report Share Posted August 25, 2021 1 hour ago, wakabal said: 2017 Edge just developed this issue. Ford denies claim on extended warranty and wants $1900 to fix. What a bunch of BS. Any help is appreciated. There's a few threads on this and the below one seems the most promising: 1 Quote Link to comment Share on other sites More sharing options...
AdrianC Posted April 25, 2023 Report Share Posted April 25, 2023 Hi guys, I have this car for 5 years now and I have changed 4 tail (haion) lamps. is got ckraking and then fills with water. is somebody faced the some problem? there is a solution? 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 27, 2023 Report Share Posted April 27, 2023 This is how one fixed the problem; claims it took him two minutes. Quote Link to comment Share on other sites More sharing options...
Will2U Posted April 28, 2023 Report Share Posted April 28, 2023 I have a 2022 model and I recently noticed that my taillights have holes drilled right in the middle of each unit on the outside. The holes are about the size in enigma-2's video but they aren't hidden away like he did. You don't notice them unless you look and they don't let water in (that I can tell). I've never had condensation in my lights. Quote Link to comment Share on other sites More sharing options...
Mikedaddy 2018 Edge Posted July 7, 2024 Report Share Posted July 7, 2024 On 10/9/2017 at 2:10 PM, Mjbl1122 said: We have the same issue excepting the condensation never goes away. We have been traveling all summer and when we were in Arizona we noticed condensation in both tail lights and the strip in between the tail lights. We are now back in Florida, 5 months later and took the car into the dealer as the condensation has gotten worse. The dealer ordered the parts but when they went to get warranty approval we were denied. We are told that Engineering said the condensation will clear up. Well it's been 5 months now, how long do we have to wait for the condensation to clear up. I think Ford needs to get new engineers. The condensation is causing real concern because the condensation is reducing the visability of the tail lights. This is such BS…. My 2018 loaded Edge has this same problem, never goes away… sometimes it’s droplets other times it’s a fog moisture. This should be a FORD recall. Mike Byrne Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted July 11, 2024 Report Share Posted July 11, 2024 I wish I could have the 15-18 tail lights on my 2021. Quote Link to comment Share on other sites More sharing options...
