Windshield Washer Fluid
My friend told me that the orange rain x stains his cars..... I never had a problem with it....Decided to put it my black edge and never really gave any thought to it until I needed to use it.... FF few weeks later I use my windshield washer and it stains.
What is the best/ preferred windshield washer fluid to use. Apart from running it through the system is there a easy way to drain it?
Thanks in advance.
I'm not the right person to ask, I use any cheapo fluid with the right freeze rating (lower in wintertime) :) Are you looking for a product to coat your glass? If so, apply the RainX directly. Or get Aquapel (better). Or get by FlyBy30 (best). Maybe a sealant for your paint would protect it from staining, a wax wouldn't cut it for long. Then you could continue to use RainX WWF. Although that seems like the cart leading the horse.
I thought that using the orange Rain X would be the easiest albeit the cheapest soloution. I have used Rain X directly in the past. I just happened to be out and figured might as well kill two birds with one stone. I've seen Aquapel before but never heard of FlyBy30. If you do a quick google for Rain X stains paint you will see it on plenty of forums. If I have time this weekend I'll drain it and get something cheap that has antifreeze properties in it.
Thanks for the advice.
If you read the reviews on Amazon, they are overwhelming negative. A common complaint is the crap coats the electrical connectors in the resivoir and leaves the low fluid light on permanently. Chrysler has a TSB on repairing the electronic sensor but makes it clear the owner is responsible for the costs.
Another complaint is under certain curcumstances the fluid coats the windshield with a white film making it impossible to see clearly.
This stuff is complete crap.
