Z51 LS3 Posted September 12, 2015 Report Share Posted September 12, 2015 Hello, FE Forum! Wish my first post was under different circumstances. My wife's 2012 SEL Eco has been having off and on battery issues. Sometimes not driving for 8-12 hrs results in dead battery. She was getting fed up with how unreliable the car was becoming, so I changed the first thing I know to - the battery. Before this I attempted to jump it with my jumper pack. The jumper pack didn't have enough juice, so after I attempted to start it, there was this very fast clicking noise coming from driver side engine compartment. I went and got new battery, mega tron 2 65, installed it, go to start it and it starts but I smell burnt fuses. Immediately notice that the sync was completely black, and inop, as were the flashers and a few others. I replaced the fuses that tested popped under the driver area. Looked at the high side and the fuses all tested good. Hooked it back up to battery and started it and it turned over but with in a few minutes went to a low power limp mode. It eventually died. Brand new battery was reading 9.4volts! Alternator was putting out 14, so it was good. Check wiring harness and the 200amp circuit breaker on the battery terminal popped. Replaced that circuit breaker and charging system is up and good, car drives, AC, sync, everything is running good, except for the flashers, turn signals, and HIDS. The passenger right Amber light (where it has "edge" engraved) is on non stop, unless I pull its fuse. The back driver side Amber light is also on non stop unless I pull its fuse. The blinkers won't work at all, even though the instrument cluster shows them on and blinking. While driving the passenger side HID is significantly brighter than the drivers side. I've tested all the fuses and they all check out, pulled relays in the high distro box and they had no significant effect. The CES light was on and threw a code for pcm write failure - too early. Cleared it but it's still showing as a "permenent code". Do these edges have a seperate bcm? Or does the pcm control everything? Thanks in advance, any ideas would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 13, 2015 Report Share Posted September 13, 2015 (edited) Any aftermarket electronics (lighting, audio, alarm system, etc.) or replacement HID bulbs (assuming OEM HID on your Edge; 35W/55W) installed recently? The fact that the new battery (assuming not very old at time of installation) was 9.4V tells you right away that there is a drain on it right away, or it is a bad unit. Connections are good, clean & tight? When you say the passenger side HID is brighter, is it "normal" bright or brighter than "normal"? Any exposure to heavy rains/car washes/high water recently? If everything else checks out: The BCM/SJB is separate from the PCM, and could be fried. It can, and has caused battery drain problems before. Also, if your Edge has the Battery Monitoring System, it needs to be reset to recognize the new battery so it can "smart charge" it properly. Here's a recall for the 2011 Edge BCM: Ford Edge, Lincoln MKX Recalled For Body Control Module February 21, 2011 - Recalls - Tagged: 2011, edge, ford, Lincoln, MKX, Recall Ford is recalling 2011 model Edge and Lincoln MKX crossover vehicles to reinspect body control modules that were the subject of a previous recall. Vehicle Make / Model: Model Year(s): FORD / EDGE 2011 FORD / F-150 2011 FORD / F-250 2011 FORD / F-350 2011 FORD / F-450 2011 FORD / F-550 2011 LINCOLN / MKX 2011 Manufacturer: FORD MOTOR COMPANY Mfr’s Report Date: FEB 21, 2011 NHTSA CAMPAIGN ID Number: 11V128000 N/A NHTSA Action Number: N/A Component: ELECTRICAL SYSTEM: SOFTWARE Potential Number of Units Affected: 8,022 Summary: FORD IS RECALLING CERTAIN MODEL YEAR 2011 FORD F-150, F-250, F-350, F-450, F-550, EDGE, AND LINCOLN MKX TRUCKS MANUFACTURED FROM OCTOBER 25, 2010, THROUGH NOVEMBER 20, 2010. THESE VEHICLES WERE INSPECTED USING INTEGRATED DIAGNOSTIC SYSTEM (IDS) THAT HAD A CUSTOM SOFTWARE ROUTINE TO READ THE SUSPECT BODY CONTROL MODULE (BCM) SERIAL NUMBER. BASED ON THE SERIAL NUMBER THE BCM WAS EITHER NOT AFFECTED OR REPLACED. THE CUSTOM SOFTWARE ROUTINE WAS NOT READING THE CORRECT SET OF CHARACTERS, AND WAS NOT ABLE TO IDENTIFY A BCM THAT REQUIRED REPLACEMENT AFFECTED BCMS MAY HAVE THE POTENTIAL FOR AN INTERNAL SHORT. Consequence: IF AN ELECTRICAL SHORT DEVELOPS, AN OVERHEATING CONDITION MAY OCCUR WHICH COULD RESULT IN A VEHICLE FIRE. Remedy: DEALER WILL INSPECT THE BODY CONTROL MODULE AND IF NECESSARY REPLACE IT FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN ON OR ABOUT MARCH 7, 2011. OWNERS MAY CONTACT FORD MOTOR COMPANY CUSTOMER RELATIONSHIP CENTER AT 1-866-436-7332. Notes: FORD SAFETY RECALL NO. 10S14. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV . Edited September 13, 2015 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
Z51 LS3 Posted September 15, 2015 Author Report Share Posted September 15, 2015 Thank you for response. The engine compartment did get wet recently. That morning I had a battery charger on the battery. I had wife snap a picture of the battery, she forgot to put hood down. It proceeded to thunderstorm after that. I think it’s probably the body control module/lighting control module. I believe these are the same two parts. I can’t find apart number for it in the 2012s though. I found 2013 7S4Z-13C788-A, but that says its not compatible for 2012. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 15, 2015 Report Share Posted September 15, 2015 It's called the smart junction box. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 15, 2015 Report Share Posted September 15, 2015 The SJB for 2012 is BT4Z-15604-B. About $140 on EBay, don't know of a separate Light Control Module here, though I see listings for them for older vehicles. Quote Link to comment Share on other sites More sharing options...
