georgetown Posted September 9, 2015 Report Share Posted September 9, 2015 I have a 2007 Edge and had a local mechanic swap out my coolant fan. I purchased the fan and he did the labor. I am driving home and the check engine light pops up. Got home and put the scanner on and these are the codes that popped up. P0060 HO2 HEATER RESISTANCE (BANK 2, SENSOR 2) P0480 FAN 1 CONTROL CIRCUIT P1000 OBD SYSTEM READINESS TEST NOT COMPLETE ANYBODY KNOW WHAT CAN CAUSE ALL OF THESE ALL OF A SUDDEN? ANY HELP WOULD BE GREATLY APPRECIATED. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 9, 2015 Report Share Posted September 9, 2015 Very disjointed codes! Which brand of fan did you have put in? We have already had one report of a TYC fan causing problems. Most likely the issues are from connectors not making proper contact, or fuses not being fully seated/in the wrong slots, etc. The P1000 can easily cascade from the P0060 code. There shouldn't have been any oxygen sensor involvement in the fan replacement, except possibly the wires getting nicked while the vehicle is on a lift for service, for example. Quote Link to comment Share on other sites More sharing options...
georgetown Posted September 9, 2015 Author Report Share Posted September 9, 2015 It was an aftermarket coolant fan Quote Link to comment Share on other sites More sharing options...
georgetown Posted September 9, 2015 Author Report Share Posted September 9, 2015 (edited) The fans are working properly but still getting codes. I erased the codes and they popped back up Edited September 9, 2015 by georgetown Quote Link to comment Share on other sites More sharing options...
georgetown Posted September 10, 2015 Author Report Share Posted September 10, 2015 Found the problem. Plug was burnt so it caused a short in wires Thanx for your help! Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted September 10, 2015 Report Share Posted September 10, 2015 This is the fan module plug? Surprising it caused all 3 codes. Quote Link to comment Share on other sites More sharing options...
georgetown Posted September 28, 2015 Author Report Share Posted September 28, 2015 Fixed plug and codes went away and next day codes popping back up. Now I have P0060 HO2S Heater resistance (Bank2, Sensor 2) P1000 OBD SYSTEM READINESS TEST NOT COMPLETE What are the odds of the O2 sensor going out at the same time? Quote Link to comment Share on other sites More sharing options...
