Front License Plate Bracket
GDoll
Just moved from GA to TX with my 2014 Ford Edge Limited. Now need to install a front license plate bracket because TX has plates on front and back. Read somewhere that if you order the plate bracket you will not get the mounting hardware. Two questions - how do I get the mounting hardware and can it be installed without having to take to a dealership/garage? Thanks for any help. Glenn
EBay has the plate frames for around $20. There are 2 mounting holes that need to be drilled in the bumper. You need to insert rivnuts into the bumper to screw into. I did this on my 2007. Easy if you can get the rivnuts installed. They are similar to pop rivets with a treaded portion inside. Any good body shop can do this for you for a minimal cost.
