Metallic Click/Pop Noise
VisceralSauce
This happens at random.
Shortly after my start up in the mornings and just a couple blocks into my commute.
I'll hear a metallic click once or twice.
It sounds as if it's coming from under the back seats?
~150,000 miles
I've only had one "accident" where I went off the interstate in winter of 13/14
There was no serious damage done, a crack in the wheel cover was all I noticed and continued my 600 mile drive home.
This just started over the past month or two, surely it's not connected?
Any help would be appreciated.
These sounds can be hard to pinpoint. Check to make sure seat tracks are bolted down properly, bolts/nuts are not spinning freely. Check underneath car to see if any of the fuel/brake lines have come loose, or the shield for the EVAP system components has come loose/become damaged. Check for play in the driveshaft support bearings.
