Brakes Squeak While Braking in Reverse Only
This started after having all brakes replaced by STS (first mistake, I know)
I have a 2008 Ford Edge SEL AWD
Just under 151,000 miles.
When in reverse only, when I apply the brakes, they squeak something horrible.
The pads are fine.
This isn't just a "now and then" occurrence.
It's every time I back out of a parking spot or parallel park.
Any reason why this is happening?
What should I look for?
Easy fixes?
All help appreciated.
You could try this out. Low frequency damper can be added to the 08 edge with a new pin kit and the dampers. Your noise will and should disappear.
The pads are fine.
Easy fixes?
  • 9 years later...
Same boat! 👋
I have a 2012 Ford Edge Limited Sport.
Just under 124,000 miles.
Expand
I've had them inspected 3x by two different shops and they're saying it's just a little moisture or some other debris.   Nothing to fret over.  Well I've had it.  It's embarrassing! Any ideas?
Edited by 1004ron
