Need to swap heavily damaged wheels - Will these work?
Richard Mead
I have a 2007 Ford Edge with the 18" chrome clad wheels (I've found sites saying they're 18x8 and 18x7.5)
I found a set of wheels on CL near me that look good and need to know if I'd have issues with them:
http://atlanta.craigslist.org/atl/pts/5125597552.html
From the research I've done, the offset on the Edge wheels is 44mm, the offset on the Taurus ones is 39mm.
Help?
Is the centerbore the same as for your Edge? The 2007 Edge is 70.6, 2011+ Edge is 63.4. Not sure on the Taurus, I THINK they are 63.4 also. You might need an adapter depending on the answer, shouldn't be a big deal if the Taurus wheels are same or larger centerbore than your Edge. 18x8 and 39 Offset looks OK.
Edited by WWWPerfA_ZN0W
