foxxyfox Posted August 22, 2015 Report Share Posted August 22, 2015 (edited) Sometimes when I approach the vehicle with the key fob in my pocket it'll auto unlock the door but then other times I have to press the unlock button on the key fob. I've been looking in the manual to see under what conditions it automatically unlocks the door and can't find anything. Anyone have any additional information about this? Edit: Looks like I sort of found the information I was looking for, page 62 Activating Intelligent Access (If Equipped)You must have the intelligent access key within 3.3 ft (1 m) of your vehicle. At a DoorPull an exterior door handle to unlock and open the door. Make sure not to touch the lock sensor area on the front of the handle. Touch the top of the door handle to lock your vehicle. There will be a brief delay before you can unlock your vehicle again.Note: Keep the door handle clean to make sure the system operates correctly. Edited August 22, 2015 by foxxyfox Quote Link to comment Share on other sites More sharing options...
akirby Posted August 22, 2015 Report Share Posted August 22, 2015 Yes, you have to touch the inside of the door handle. Quote Link to comment Share on other sites More sharing options...
squeaky Posted August 30, 2015 Report Share Posted August 30, 2015 The car will not auto lock correct? My previous car ( Mazda CX-5) all I had to do is walk away from the car with key fob in my pocket and the doors would auto lock I can' seem to find anything in the manual that would indicate the Edge auto locks when you walk away? Quote Link to comment Share on other sites More sharing options...
foxxyfox Posted August 30, 2015 Author Report Share Posted August 30, 2015 No it doesn't autolock when you exit the vehicle. You can lock it by touching the top of the door handle (see picture in first post), with the key fob or (what I do) just press the lock button on the inside of the car Quote Link to comment Share on other sites More sharing options...
