Thomaswh3 Posted August 22, 2015 Report Share Posted August 22, 2015 I have a 2013 edge limited that I bought new . I took it to the dealer for a oil change and I told the service writer about a bad odor after I use the ac and park it in the garage . She checked her ford tsb list and said there was a fix for it . TSB -14-0045 . It requires replacing the evaporator and housing with a new redesigned unit . She said they have to remove the dash to do it . Has anyone had this done ? I really don't want my dash taken out but the smell is really bad .After I drive it with the air on my head starts to stop up and I get sinus pressure . Thanks for any advice . I only have 13000 miles on it . Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 22, 2015 Report Share Posted August 22, 2015 #1 Change the cabin air filter, probably filthy. Easy DIY. #2 Check to see if water drips under the car when standing after having used AC for some time. If not, it is clogged. There is a connection near the driver side of the center console under the carpeting you can access to blow it out. #3 Spray Lysol (or a foaming AC cleaner product such as from BG or Lubegard; follow instructions) in the vents via the windshield cowl with the engine running and heat on high/blower on high after doing the above. If you still perceive the problem, go in for the TSB fix. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 26, 2015 Report Share Posted August 26, 2015 FYI, here's an excellent video on YouTube showing how to clean the evaporator housing using Lubegard's Kool-It. https://www.youtube.com/watch?v=Bi22mdXj3wM 1 Quote Link to comment Share on other sites More sharing options...
normcloutier Posted August 26, 2015 Report Share Posted August 26, 2015 Can you post the TSB or a link to it? Quote Link to comment Share on other sites More sharing options...
Thomaswh3 Posted August 26, 2015 Author Report Share Posted August 26, 2015 (edited) On this website under recalls, TSB's , warranty . Musty - organic odor smell . July 7 ,2015 . TSB 14-0045 . The Ford dealer told me that it is a new design housing that drains better . Edited August 26, 2015 by Thomaswh3 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 26, 2015 Report Share Posted August 26, 2015 TSB 14-0045MUSTY OR ORGANIC ODOR FROM FRONT VENTS – AIR CONDITIONING (A/C) IS ACTIVATED – BUILT ON OR AFTER 4/6/2012Publication Date: March 5, 2014FORD: 2013 EdgeLINCOLN: 2013 MKXISSUE:Some 2013 Edge and MKX vehicles built on or after 4/6/2012 may exhibit a musty or organic odor coming from the front vents when A/C is activated.ACTION:Follow the Service Procedure steps to correct the condition.SERVICE PROCEDUREReplace the air conditioning evaporator housing assembly. Refer to Workshop Manual (WSM), Section 412-01.PART NUMBER/PART NAMECT4Z-19B555-G Complete Asy, Production-Installed Type, Includes Evaporator Core, Thermostatic Expansion Valve (TXV) And Evaporator Temperature Control Sensor, From: 4/3/2012 2013/ ; Humidity SensorCT4Z-19B555-H Complete Asy, Production-Installed Type, Includes Evaporator Core, Thermostatic Expansion Valve (TXV) And Evaporator Temperature Control Sensor, From: 4/2/2012 2013/ ; Humidity SensorCT4Z-19B555-J Complete Asy, Production-Installed Type, Includes Evaporator Core, Thermostatic Expansion Valve (TXV) And Evaporator Temperature Control Sensor, From: 4/3/2012 2013/ ; Less Humidity SensorCT4Z-19B555-K Complete Asy, Production-Installed Type, Includes Evaporator Core, Thermostatic Expansion Valve (TXV) And Evaporator Temperature Control Sensor, From: 4/2/2012 2013/ ; Less Humidity Sensor9T4Z-19B555-G Complete Asy, Production-Installed Type, Includes Evaporator Core, Thermostatic Expansion Valve (TXV) And Evaporator Temperature Control Sensor, From: 4/3/2009 2013/ ; Less Humidity SensorAT4Z-9H486-A Upper Intake GasketW714878-S439 Steering Column Shaft-To-Steering Column Pinch BoltOPERATION/DESCRIPTION/TIME140045A 2013: Edge 2.0L GTDI: Replace The Evaporator Housing Assembly (Do Not Use With Any Other Labor Operations) 4.4 Hrs.140045A 2013: Edge 3.5L/3.7L: Replace The Evaporator Housing Assembly Includes Time To Remove And Install Upper Intake Manifold (Do Not Use With Any Other Labor Operations) 5.3 Hrs.140045A 2013: MKX 3.7L: Replace The Evaporator Housing Assembly Includes Time To Remove And Install Upper Intake Manifold (Do Not Use With Any Other Labor Operations) 5.4 Hrs.WARRANTY STATUSEligible Under Provisions Of New Vehicle Limited Warranty Coverage. Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.DEALER CODING/BASIC PART NO./CONDITION CODE19B555 42 Quote Link to comment Share on other sites More sharing options...
Ronnie Ray Ogg Posted August 27, 2015 Report Share Posted August 27, 2015 I have the same issue it really stinks that mine is out of warranty now. I wish there were some way to get Ford to make this a recall Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 28, 2015 Report Share Posted August 28, 2015 I have the same issue it really stinks that mine is out of warranty now. I wish there were some way to get Ford to make this a recallHow far out of warranty is your car? Have you ever complained about it during the warranty period? Sometimes Ford makes goodwill repairs if warranty just expired. Try contacting the Ford rep in the forum for assistance. 1 Quote Link to comment Share on other sites More sharing options...
normcloutier Posted August 28, 2015 Report Share Posted August 28, 2015 Is this for US vehicles only? I still cant find the TSB on ford.com Can someone post the url? Quote Link to comment Share on other sites More sharing options...
Dukhaykh Posted September 13, 2015 Report Share Posted September 13, 2015 It's not just in USA cars. I am from Middle East and I've been noticing this for a while, pretty much ever since ive had my 2014 edge. This only happens when i accelerate really fas, anyone know why? Quote Link to comment Share on other sites More sharing options...
normcloutier Posted September 30, 2015 Report Share Posted September 30, 2015 Has anyone had the repair done? I am afraid that removing and replacing parts will lead to more unrelated problems. I had the door sensor replaced on my 13 SEL and I have been back to the dealer 5 times for rattles/squeaks in the drivers door panel. Still not fixed. Things never go back together the same as on the production line. Quote Link to comment Share on other sites More sharing options...
omar302 Posted October 1, 2015 Report Share Posted October 1, 2015 It's not just in USA cars. I am from Middle East and I've been noticing this for a while, pretty much ever since ive had my 2014 edge. This only happens when i accelerate really fas, anyone know why? I believe this is you issue. Quote Link to comment Share on other sites More sharing options...
