Trying to figure out this vibration....
Recently changed my 22s back in April of this year. The place I purchased them from had a really hard time balancing the tires, it was to the point where I actually went somewhere else because I was fed up. The new place rebalanced and things were fine...until I rotated them last weekend after 6000 miles. When I am turning left from 60mph and up, there is a vibration. The vibration only occurs when turning left and can be felt a little in the steering wheel but I notice it more in my seat. My Edge has AWD and 60k miles.
Something tells me maybe this isn't a wheel balance issue. What I do know is this vibration started after I replaced my original tires back in April.
Thoughts?
Could just be a bad wheel/tire combo, became obvious when that rear tire got moved to active duty in the front. Hopefully you can get a re-alignment/balancing for free? The Paradas are quality tires, but there could be a dud once in a while. 22" OEM wheels have been known to crack, so I would have them inspected very closely.
Or could be a driveshaft bearing issue that happens to coincide with the tire purchase/rotation.
Update...Brought it back to the tire shop where I purchased. They rebalanced yet again, for the 4th time...Vibration went away which is good...
They said the rims aren't bent, the car wasn't pulling but I had them do an alignment since its never been done.
So all is good....for now. Curious to see what happens when I get them rotated in 6,000 miles...
Side note, any tips on removing the gunk where the old weights were placed inside the rim? I have a lot of it now!
