GT500R Posted August 18, 2015 Report Share Posted August 18, 2015 Has anyone figured out how to make the front passenger "cigarette lighter" power source ignition only powered? My VW turns off power once the ignition is turned off and it's a great feature since I don't have to constantly plug in my radar detector in and out. Thanks Link to comment Share on other sites More sharing options...
WingNut Posted August 18, 2015 Report Share Posted August 18, 2015 I wasn't aware that it provided uninterrupted power. This weekend my Edge was off and I needed to charge my phone. So I plugged in my car charger to the 12v port on the passenger side, and there was no power. That I remember*. So I ended up just using one of my portable chargers. *Note: I was under the influence of about a 12 pack at that point. So take it for what it's worth. Link to comment Share on other sites More sharing options...
GT500R Posted August 18, 2015 Author Report Share Posted August 18, 2015 I wasn't aware that it provided uninterrupted power. This weekend my Edge was off and I needed to charge my phone. So I plugged in my car charger to the 12v port on the passenger side, and there was no power. That I remember*. So I ended up just using one of my portable chargers. *Note: I was under the influence of about a 12 pack at that point. So take it for what it's worth. Note: If used when the vehicle is not running, the battery will discharge. There may be insufficient power to restart your vehicle. <- directly from user manual Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 18, 2015 Report Share Posted August 18, 2015 The manual certainly implies the power point is always on. Run the vehicle for full capacity use of thepower point. To prevent the battery fromdischarging accidentally:• Do not use the power point longer thannecessary when the vehicle is notrunning.• Do not leave devices plugged inovernight or when you park your vehiclefor extended periods. Link to comment Share on other sites More sharing options...
akirby Posted August 18, 2015 Report Share Posted August 18, 2015 It seems to vary from vehicle to vehicle and year to year as to whether certain power points are always on or not. Link to comment Share on other sites More sharing options...
WingNut Posted August 18, 2015 Report Share Posted August 18, 2015 It seems to vary from vehicle to vehicle and year to year as to whether certain power points are always on or not. Correct. Because I just went out there again, opened up my passenger door, plugged in my charger, and no power. I didn't turn the car on at all. Link to comment Share on other sites More sharing options...
GT500R Posted August 18, 2015 Author Report Share Posted August 18, 2015 Correct. Because I just went out there again, opened up my passenger door, plugged in my charger, and no power. I didn't turn the car on at all. 2015 Ford Edge Sport? Link to comment Share on other sites More sharing options...
GT500R Posted August 19, 2015 Author Report Share Posted August 19, 2015 Correct. Because I just went out there again, opened up my passenger door, plugged in my charger, and no power. I didn't turn the car on at all. 2015 Ford Edge Sport? So just sent out to my car this morning and didn't turn ignition on/car on and my charger had no power either UNTIL I turned it on... WTF is going on here?! Does it shut off after a certain amount of time? Anyone know what the logic is here? Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 19, 2015 Report Share Posted August 19, 2015 All I know is there is generally a 10 minute "courtesy" power ON after engine is turned off unless (driver?) door is opened before that time is up. There is also, at least on 2011 & newer, a battery saver timeout of 45 minutes (or less if the battery level is detected to be at threshhold before that). Logic is primarily to allow accessories to be run without using engine power, such as traveling with passengers, running a short errand, vacuuming the interior etc. Link to comment Share on other sites More sharing options...
akirby Posted August 19, 2015 Report Share Posted August 19, 2015 It's called delayed accessory power and it stays on for 10 minutes or until you open the door. Link to comment Share on other sites More sharing options...
DBeth Posted August 19, 2015 Report Share Posted August 19, 2015 I've been using the 12V power port in the middle armrest and have noticed no power in it until I turn the car on as well. Link to comment Share on other sites More sharing options...
GT500R Posted August 21, 2015 Author Report Share Posted August 21, 2015 It's called delayed accessory power and it stays on for 10 minutes or until you open the door. Can you explain how the feature works step by step? I've been using the 12V power port in the middle armrest and have noticed no power in it until I turn the car on as well. Stayed on after I shut the car off, locked, and came back 25 minutes later..... Link to comment Share on other sites More sharing options...
akirby Posted August 21, 2015 Report Share Posted August 21, 2015 After you shut off the engine, the radio, windows, etc. still operate for 10 minutes or until you open a door. Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 21, 2015 Report Share Posted August 21, 2015 How about 45 min to 1 hr later? Should be off by then if working correctly. Stayed on after I shut the car off, locked, and came back 25 minutes later..... Link to comment Share on other sites More sharing options...
