2011 MKX Driver Cooled/Heated Seat Burning?
So I finally removed the back of the seat backs of my 2011 MKX to check the cooling/heating function & what a surprise (unpleasant) I found.
The driver's seat, for which I use the cooling function routinely, is missing what seems like a heat sink made up of 2 joined metal plates. Also there is clear burn marks on the seat foam.
You can see both the driver & passenger seats & the metal plates on the passenger seat as well as the seat foam burn which is only on the driver seat, the cooling/heating function of the passenger seat is rarely used.
Note: the seat back does have it own cooling/heating module separate from the seat bottom which can also be seen in the photos.
Driver Seat:
Passenger Seat with the metal plates:
Burn marks on the driver seat foam:
Vehicle is now at the dealer for service & to look at this.
