s4tom3 Posted August 10, 2015 Report Share Posted August 10, 2015 Anyone replace their 9005 halogen bulb with an LED. I know some have successfully changed the H15 (HID equipped Sport) with an LED. Looking for a white light, not factory yellow. Would these work? Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 10, 2015 Report Share Posted August 10, 2015 (edited) I wouldn't recommend that since the same bulb is used for DRL & High Beams. The 9005 is a single filament bulb, usually, to get the DRL function, the bulb would run at reduced voltage so to get the LED to work, you might need some kind of module (example) to get it running correctly. Also, note that you might end up with a very bright DRL (too bright), or you high beams will become less bright compared to stock. Edited August 10, 2015 by omar302 Quote Link to comment Share on other sites More sharing options...
s4tom3 Posted August 11, 2015 Author Report Share Posted August 11, 2015 Thanks omar302. Quote Link to comment Share on other sites More sharing options...
