lpgao Posted August 4, 2015 Report Share Posted August 4, 2015 what I should know to replace my rear pair of tires? can I put wheels to front after I replace them with new tire? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 4, 2015 Report Share Posted August 4, 2015 If you have AWD, always replace all 4 tires, as a rule. If you have FWD, 2 at a time is fine. If only replacing 2 tires, new tires should go on the back in a FWD vehicle, to give them time to break in properly. At the next scheduled rotation, the new tires will be ready to serve as the driven tires. Alignment whenever you get tires is a must. Quote Link to comment Share on other sites More sharing options...
fishx65 Posted August 4, 2015 Report Share Posted August 4, 2015 If you have AWD, always replace all 4 tires, as a rule. If you have FWD, 2 at a time is fine. If only replacing 2 tires, new tires should go on the back in a FWD vehicle, to give them time to break in properly. At the next scheduled rotation, the new tires will be ready to serve as the driven tires. Alignment whenever you get tires is a must. Never heard of an alignment being a must after a simple tire replacement. Have I been doing it wrong for the last 50 years??? 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 4, 2015 Report Share Posted August 4, 2015 It is if you want them to last. I suppose you could skip it if you are quite sure the alignment is spot-on, or if you drive on glass-smooth roadways. But those are a distant memory now, even with new roads or resurfaced roads ... Quote Link to comment Share on other sites More sharing options...
carguy75 Posted August 4, 2015 Report Share Posted August 4, 2015 On the newer AWD on-demand systems like in the Edge (which actually just drive the front wheels until the rear wheels slip)you can actually just buy tires in front or rear axle sets as long as they are the same tires. However, you still have to be smart about it so you should not put only new tires on one axle if the another axle have bald tires. Quote Link to comment Share on other sites More sharing options...
Redbow Posted August 5, 2015 Report Share Posted August 5, 2015 Shortly after purchasing my 2013 Edge SE I noticed a wheering noise. Service Guy said it was tire noise and would go away. Front tires were newer Kelley's, rear were a little older Hankook. Drove me nuts for 2 months(700 miles). Replaced the tires with (4) new ones and the noise is gone. So take you chances. Burke Quote Link to comment Share on other sites More sharing options...
lpgao Posted August 8, 2015 Author Report Share Posted August 8, 2015 thanks for guys nice replies. I appreciate very much. I decide not to replace tires for now because tire just got a nail and it was repaired. Quote Link to comment Share on other sites More sharing options...
macbwt Posted August 9, 2015 Report Share Posted August 9, 2015 Those Hancooks are like dump truck tires LOL Shortly after purchasing my 2013 Edge SE I noticed a wheering noise. Service Guy said it was tire noise and would go away. Front tires were newer Kelley's, rear were a little older Hankook. Drove me nuts for 2 months(700 miles). Replaced the tires with (4) new ones and the noise is gone. So take you chances. Burke Quote Link to comment Share on other sites More sharing options...
Redbow Posted August 10, 2015 Report Share Posted August 10, 2015 You know, I had a 1955 Pontiac Star Chiief 2dr HT, a couple years back that had bias ply tires. I replaced them with the Hankook radials and was delighted with the performance. But then again, maybe it was the difference between bias and radial. Burke Quote Link to comment Share on other sites More sharing options...
rwf78155 Posted August 10, 2015 Report Share Posted August 10, 2015 Im looking to replace my 2013 Sport fwd tires. KInd of Limited due to tire size (22's) ..... recommendations? Quote Link to comment Share on other sites More sharing options...
