i20sailor Posted August 4, 2015 Report Share Posted August 4, 2015 XL Series 'Hidden' BracketsThe visible portion of the brackets, the "front arms," can be easily removed when not towing -- remove two hitch pins to convert from towed car to road car in seconds!They're virtually invisible -- improved aestheticsComputer-cut, all-steel components for exceptional strengthEasy to install -- ROADMASTER brackets use existing attachment points on the vehicle's undercarriage -- no welding!Most install through the grille -- no scraping brackets in dips or against curbs.The bracket will fit 2007 - 2015 Ford Edge without Adaptive Cruise Control It was installed for 2 years and is in very good condition. All installation hardware included.Grill piece for 2011- 2014 Edge with correct cut-outs also included. Located in Fenton, Michigan Asking $250. Quote Link to comment Share on other sites More sharing options...
