problem with the High beams
Gilad Evron
Hi guys,
New problem in my 2011 edge: after using the high beams, i can't turn them off!
even after turning off the engine, the high lights are still on, you can see the blue light sigh on, the handle is use less...so i pull off the Plus plug in my battery and reset the system- now everything is fine but after lighting again the high beam..its stuck again...
what can i do? familiar with that problem?
thanks
Gilad
