djeyecon Posted July 27, 2015 Report Share Posted July 27, 2015 What's up guys! Just got my hands on a 2013 Edge EcoBoost model. Looking to replace the BOV (if there is one) and I'm having the hardest time finding it. Can anyone tell me where it is located and/or supply pictures? Perhaps share your mods? With boosted applications I've always been a Nissan guy. I understand this question is quite "beginner" of me, but I just can't seem to locate it. Lol. Thanks! Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 27, 2015 Report Share Posted July 27, 2015 I believe you would be looking for the vacuum valve solenoid (wastegate), but don't see it listed on the 2013 2.0L EB site (search www.levittownfordsupercenter.com). 1 Quote Link to comment Share on other sites More sharing options...
djeyecon Posted July 27, 2015 Author Report Share Posted July 27, 2015 Thank you for the reply. I'm not looking to do anything with the wastegate. I saw a BOV that Turbo Smart makes that's a 50/50 valve. Vents half back into the plumbing and half to the atmosphere. I'd like to achieve the function of removing some of the air and the form of the "wooshhhhhh". Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 27, 2015 Report Share Posted July 27, 2015 Well, they have to have some way of dealing with pressure release, just not sure HOW on this engine, at least from the parts diagrams. Would need to get hold of a service manual, such as found on EBay on DVD or paper format. Quote Link to comment Share on other sites More sharing options...
Larry Care Posted July 27, 2015 Report Share Posted July 27, 2015 Maybe the same spot as the Focus https://www.youtube.com/watch?v=AExA1OIigjk http://www.cjponyparts.com/turbosmart-blow-off-valve-kompact-shortie-dual-port-focus-st-2013-2015-ecoboost-3-5l-f150-2011-2012/p/TS02031061/ 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 27, 2015 Report Share Posted July 27, 2015 (edited) Nice find! A lot more work than putting one on the 3.5 EB for sure! http://www.focusst.org/forum/focus-st-performance/12705-turbosmart-dual-port-blow-off-valve-ts-0203-1060-1061-setup-faq.html Edited July 27, 2015 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
Larry Care Posted July 27, 2015 Report Share Posted July 27, 2015 Don't forget the 3.5 EB will need Qty2. CJ Pony Parts has a great site Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 27, 2015 Report Share Posted July 27, 2015 (edited) K, I think I found the OEM part (bypass valve) on EBay BL3Z9K378A: http://www.ebay.com/itm/NEW-OEM-TURBOCHRAGER-BYPASS-VALVE-2010-2015-FORD-LINCOLN-VEHICLES-BL3Z-9K378-A-/231449794421? Here is an applications list from the same listing: 2011-2014 Ford F-150 - 3.5L2015 Ford Transit - 3.5L2015 Ford Expedition - 3.5L2015 Lincoln Navigator - 3.5L2013-2015 Ford Fusion - 2.0L EcoBoost2013-2015 Lincoln MKZ - 2.0L EcoBoost2013-2015 Ford Focus - 2.0L EcoBoost2010-2015 Lincoln MKS - 3.5L2013-2015 Ford Escape - 2.0L EcoBoost2015 Lincoln MKC - 2.0L EcoBoost2010-2015 Ford Flex - 3.5L2010-2015 Lincoln MKT - 3.5L2013-2015 Lincoln MKT - 2.0L EcoBoost2012-2015 Ford Edge - 2.0L EcoBoost2012-2015 Lincoln MKX - 2.0L EcoBoost2013-2015 Ford Explorer - 3.5L2012-2015 Ford Explorer - 2.0L EcoBoost2010-2015 Ford Taurus - 3.5L2013-2015 Ford Taurus - 2.0L EcoBoost Edited July 27, 2015 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
djeyecon Posted July 28, 2015 Author Report Share Posted July 28, 2015 Nice find! A lot more work than putting one on the 3.5 EB for sure! http://www.focusst.org/forum/focus-st-performance/12705-turbosmart-dual-port-blow-off-valve-ts-0203-1060-1061-setup-faq.html This article led me to this..... http://www.focusst.org/forum/focus-st-performance/4929-rallysport-direct-installs-turbosmart-dual-port-bov-white-sheep.html Nice find on this and thanks for the Focus video Larry. I actually called Turbosmart today and their response to this fitting a "2013 2.0 Ecoboost Edge" was, "Sorry we can't give you a definitive answer because we've never fitted that application". I'm assuming the reason for that is because the Edge isn't typically a highly and frequently modified vehicle so Turbosmart hasn't received enough demand to get their hands on an Edge and fit the BOV. So, what to do? Well, I have a service appt tomorrow and I'm going to talk to the writer about the Focus/Fusion/Edge and reference some part numbers. It would seem the 2.0 Ecoboost is the same across the platforms referenced from here.... (https://en.wikipedia.org/wiki/Ford_EcoBoost_engine). I believe I'm just going to have to pull the wheel, take a look for myself and see what's up. I'll report my findings. Thoughts on this guys? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 28, 2015 Report Share Posted July 28, 2015 Agreed. Talk with your SA, then it's time to investigate. Quote Link to comment Share on other sites More sharing options...
RJG Posted July 28, 2015 Report Share Posted July 28, 2015 No matter....it won't make much of a performance difference. 4000 lb vehicle with a turbo 2.0 engine.....still less than 300 ft lbs tq with 10% more boost....you'll probably just mess it up. And you will need a tune. And that's assuming injectors and fuel system are up to task. Quote Link to comment Share on other sites More sharing options...
djeyecon Posted July 28, 2015 Author Report Share Posted July 28, 2015 No matter....it won't make much of a performance difference. 4000 lb vehicle with a turbo 2.0 engine.....still less than 300 ft lbs tq with 10% more boost....you'll probably just mess it up. And you will need a tune. And that's assuming injectors and fuel system are up to task. RJG I'm not looking to increase the boost. The BOV recirculates the expelled air back into the turbo after the MAF so even if you removed all of it, the vehicle wouldn't know the difference. A tune will not be necessary. I'm not trying to improve my 1/4 mile times here. Lol. It's a fact venting the air is better for the turbo. I'm also looking to hang onto my boost roots with the "wooshhhhh". Quote Link to comment Share on other sites More sharing options...
RJG Posted July 28, 2015 Report Share Posted July 28, 2015 I know what it does. I've built turbo race engines before. Just don't see the point in that vehicle. Quote Link to comment Share on other sites More sharing options...
djeyecon Posted July 28, 2015 Author Report Share Posted July 28, 2015 I know what it does. I've built turbo race engines before. Just don't see the point in that vehicle. Well alright then. I don't understand how you can argue it being better for the turbo and where you came up with "you'll probably just mess it up". So, thanks for the information I guess. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 28, 2015 Report Share Posted July 28, 2015 Hope you will do a writeup if & when you decide to tackle this project, djeyecon Quote Link to comment Share on other sites More sharing options...
djeyecon Posted July 29, 2015 Author Report Share Posted July 29, 2015 Hope you will do a writeup if & when you decide to tackle this project, djeyecon Alright, so last night I pulled the wheel and the inner fender lining off to take a look. The BOV looks to be the same to me visually. Now that I know it's there, All there is left to do is order the TurboSmart valve and see if it bolts up. The install however will not be as easy in terms of accessibility as it is on the focus but I believe there's enough room. Let's see how this goes..... 1 Quote Link to comment Share on other sites More sharing options...
djeyecon Posted July 29, 2015 Author Report Share Posted July 29, 2015 :: Update ::Ordered the 50/50 TurboSmart BOV from CJPony. Part# : TS-0203-1061. Paid for 2 day shipping so in theory it will be here Thursday. This is getting interesting, lol. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 29, 2015 Report Share Posted July 29, 2015 Sound clips before and after! Will likely have to cut that hose a little since the OEM connection comes out straight and the TS connection is at 90 degrees, plus external body looks to be significantly larger. 1 Quote Link to comment Share on other sites More sharing options...
djeyecon Posted July 30, 2015 Author Report Share Posted July 30, 2015 Sound clips before and after! Will likely have to cut that hose a little since the OEM connection comes out straight and the TS connection is at 90 degrees, plus external body looks to be significantly larger. I'll be sure to do that. The TurboSmart unit actually comes with interchangeable vacuum nipples. 90 degree and a straight attachment. Simple as unscrewing the 90 degree and replacing it with the straight. Woo hoo! Tracking is showing "End of Day" Friday so we'll see what UPS does for me. 1 Quote Link to comment Share on other sites More sharing options...
djeyecon Posted July 31, 2015 Author Report Share Posted July 31, 2015 (edited) :: Update ::Part 1 - Stock removal is done. I could not be any LESS impressed and honestly somewhat disappointed by the stock unit. You really can't get a good feel of how awful the stock BOV is until you hold it in your hand........ in pieces. I'm going to reference this Focus install that CJ Pony did in my writeup and make note of the differences on the Edge. Focus ST Turbosmart Dual Port Blow Off Valve Installation 2013-2014 - BOV Removed... Stock BOV... BOV will be here today, I'll update asap. Edited July 31, 2015 by djeyecon 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 31, 2015 Report Share Posted July 31, 2015 OEM parts are meant to a job, and when they are not seen or looked for, they get as basic as possible As long as they function correctly, I am OK with that! But no doubt, if there is an upgrade like the TurboSmart, why not? Quote Link to comment Share on other sites More sharing options...
djeyecon Posted August 3, 2015 Author Report Share Posted August 3, 2015 (edited) Sound clip time!!!!!! Give me your thoughts guys! Edited August 3, 2015 by djeyecon Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 3, 2015 Report Share Posted August 3, 2015 I like it! Loud but not obnoxious Good going! Quote Link to comment Share on other sites More sharing options...
RustyEdge Posted August 4, 2015 Report Share Posted August 4, 2015 No matter....it won't make much of a performance difference. 4000 lb vehicle with a turbo 2.0 engine.....still less than 300 ft lbs tq with 10% more boost....you'll probably just mess it up. And you will need a tune. And that's assuming injectors and fuel system are up to task. I'm assuming you're statement about messing it up is referring to the fact that he car might run a little rich between shifts now. The ECU probably accounts for the air that's vented to the atmosphere and delivers the appropriate amount of fuel. But now that half of that air was vented instead of recirculated it could cause a brief stint of richness unless the car were tuned for such. That's what happened with my Subaru. Not really a big deal for a car like this since we're not racing and it's not worth the cost of a custom tune on a stock motor. I agree the woosh sound is pretty awesome and addicting, I used to rev my Subaru while cruising just to make it sneeze! -Russ 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 4, 2015 Report Share Posted August 4, 2015 "sneeze" Quote Link to comment Share on other sites More sharing options...
