Transmission Service
Gr8ride
Hi,
I have a 2008 Ford Edge Limited FWD. It has a little over 47K miles on it right now.
I would like to change the transmission fluid but I don't know what type or how much fluid it takes to complete this project.
The fluid that is in it now is clear and doesn't really have an odor. I thought it should be red right?
Also, the other day I started experiencing a very rough 1st to 2nd shift under light acceleration. If I accelerate hard it shifts fine. All other shifts are normal.
Thanks,
Gr8ride
Jumping on your thread... sorry, don't have any answers for you. I do know that trans fluid does have to be changed as early as you are but I guess it won't hurt. If you're thinking that'll clear up the rough shifting... you may have speed sensors going out like I am.
Labor time is the issue as I understand the sensors (2) are in the 30 buck range. I heard Ford will charge 800 or so for the repair. Ugh.
The trans fluid is Mercon V, system capacity is about 12 quarts, but if you do a 3 time drain & fill to "flush" it, you need about 15 quarts, as each drain will net 5 quarts.
Is it a rough shift, or a bump-type feeling? There is a TSB for a bump that occurs in the 0-8 mph range when turning a corner or accelerating from a stop.
tsb11-05-06 Sluggish acceleration from stop or low speed followed by bump.pdf
