cgblake1 Posted July 22, 2015 Report Share Posted July 22, 2015 2013 Ford Edge key fob or IKT (Integrated Keyhead Transmitters) will lock the doors but will not unlock the doors. What could be causing this issue? Quote Link to comment Share on other sites More sharing options...
akirby Posted July 22, 2015 Report Share Posted July 22, 2015 Does it happen on both fobs/IKTs? Quote Link to comment Share on other sites More sharing options...
cgblake1 Posted July 22, 2015 Author Report Share Posted July 22, 2015 I bought the car used and I only have 1fob/IKT. Quote Link to comment Share on other sites More sharing options...
akirby Posted July 22, 2015 Report Share Posted July 22, 2015 Then my guess would be either a bad fob or a bad battery in the fob. 1 Quote Link to comment Share on other sites More sharing options...
cgblake1 Posted July 22, 2015 Author Report Share Posted July 22, 2015 Thanks akirby! I will change the battery and see if that helps. Quote Link to comment Share on other sites More sharing options...
akirby Posted July 22, 2015 Report Share Posted July 22, 2015 If not it's probably just the button that's worn out. You might want to just buy 2 new IKTs. You'll have to get the dealer to program a new key anyway. You can't do it yourself with just one. Quote Link to comment Share on other sites More sharing options...
Eissa Posted July 22, 2015 Report Share Posted July 22, 2015 I had the same thing but I noticed that this happens after working hours where the key is left at cold conditions in the office for long time so this affects the battery, you can check if the same happens with you, when you face it again try checking the other buttons may be the alarm if it works or not,if not then my guess is right & it is just cold conditions Quote Link to comment Share on other sites More sharing options...
cgblake1 Posted July 23, 2015 Author Report Share Posted July 23, 2015 I replaced the battery in the key fob/ikt but no change; still only unlocks the door. I don't thinks the issue is due to cold conditions because temps my way in the high 90s. Looks like the button may just be worn out. I really hate to have to purchase a new IKT. I've heard these are expensive. Any ideas on where to purchase them cheaper than dealer price? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 23, 2015 Report Share Posted July 23, 2015 Unfortunately, it is time to visit the dealer. You can buy blanks on EBay, but dealers generally won't work with those keys. So the best answer to your question is still what akirby posted above. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 23, 2015 Report Share Posted July 23, 2015 On 7/23/2015 at 9:52 AM, WWWPerfA_ZN0W said: Unfortunately, it is time to visit the dealer. You can buy blanks on EBay, but dealers generally won't work with those keys. So the best answer to your question is still what akirby posted above.Mostly true, but there is one way. I bought OEM Lincoln fobs off Ebay, still sealed in oem plastic. He asked who I bought them from & told him the name of the dealer (that was selling on ebay). Shrugged and told me the price to cut the keys. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 23, 2015 Report Share Posted July 23, 2015 So the EBay seller is an authorized Ford/Lincoln dealer? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 24, 2015 Report Share Posted July 24, 2015 Yes. Forget who but was a parts Mgr for a Ford dealership. Price wasn't really cheap, but much better than local. 1 Quote Link to comment Share on other sites More sharing options...
cgblake1 Posted August 6, 2015 Author Report Share Posted August 6, 2015 Hi Guys - Wanted to let you know that I was able to purchase 2 new uncut key fobs/IKT from the Ebay vendor 'Your Key Supplier' for $33. I took them to my local dealership and they cut and programmed the keys for $75. This was far less than purchasing 1 key fob/IKT from the dealership. I did check with the dealership prior to purchasing online to make sure that they would cut and program the keys for me. Thanks for all your help. You guys saved me a lot of money ! Quote Link to comment Share on other sites More sharing options...
sman83 Posted August 13, 2015 Report Share Posted August 13, 2015 On 8/6/2015 at 12:23 PM, cgblake1 said: Hi Guys - Wanted to let you know that I was able to purchase 2 new uncut key fobs/IKT from the Ebay vendor 'Your Key Supplier' for $33. I took them to my local dealership and they cut and programmed the keys for $75. This was far less than purchasing 1 key fob/IKT from the dealership. I did check with the dealership prior to purchasing online to make sure that they would cut and program the keys for me. Thanks for all your help. You guys saved me a lot of money ! I just got my 2013 Edge Sport, and it only came with one key. The dealer is looking into getting me another key for no charge but in the mean time I am shopping around. I did a search on eBay for the seller you mentioned but it didn't pull up anything. I did find a seller for $55 a piece selling used but like new key fobs. Quote Link to comment Share on other sites More sharing options...
cgblake1 Posted August 15, 2015 Author Report Share Posted August 15, 2015 http://stores.ebay.com/Your-Key-Supplier Quote Link to comment Share on other sites More sharing options...
