My intro
Weldfreak
Hello all,
Ill go by weldfreak for now but I Just recently purchased my 2007 edge sel. I'm looking to upgrade a few things here and there. I'm a welder/fabricator and auto tech so it tends to happen. I've built plenty of turbo cars and unfortunately this one is not a turbo car but it's still way more fun then the caliber sxt I had.
Edited by Weldfreak
It was purchased used at a local dealer. It's got 119k on it. I've put 1100 of those miles on it. I'm probably going to do fabricate some misc parts for it. I want to build a set of headers for it and bolt on a magnaflow cat back cold air intake and sct tuner. Brakes maybe just some drilled and slotted rotors and a more aggressive pad. Possibly a nice set of lowering springs. I'm in the process of building a trailer for my 91 awd turbo talon so I may try to pull it with this. I've read it'll pull 3500lbs so with my car and trailer I'm hoping to be under that.
If you are going to tow with it you may want to reconsider drilled and slotted rotors. The drill points will cause heat temp differences and cause the rotors to start fracturing at the drill points. Better to go with High carbon steel and ceramic pads of good quality. Then again you may be over weight with this towing combo. Drive safe.
