Kevin Su Posted July 17, 2015 Report Share Posted July 17, 2015 I have been dealing with various noises in my 2015 Edge Titanium V6 since day one. The latest been a high pitch rattle in the front cabin. Initially I thought the rattle was coming from the passenger side, near the A pillar. I managed to eventually track down the central console cup holder as the source, much to my surprise. The high pitch rattle goes away whenever I put pressure on the cup holder. I plan to schedule a service visit with the dealer to see what they can do. Has anyone else experience a similar problem with your Edge? Quote Link to comment Share on other sites More sharing options...
Rextang Posted July 17, 2015 Report Share Posted July 17, 2015 I experienced this too. I pinned it down to the flat area of the glossy black panel between the cup holder and the arm rest. When the noise occurs, I apply downward pressure to this area and the noise subsides. After a few weeks of this, I haven't had the noise come back, so it just may be that the underlying adhesive wasn't fully mated to the outer panel. Give it a try and report back. Quote Link to comment Share on other sites More sharing options...
Frank Drebin Posted July 17, 2015 Report Share Posted July 17, 2015 Same rattle from the cup holder here... Quote Link to comment Share on other sites More sharing options...
Frank Drebin Posted July 17, 2015 Report Share Posted July 17, 2015 @Kevin Sue, look at my post "Rattle drive me crazy" if you experienced the same rattle as me Quote Link to comment Share on other sites More sharing options...
stevews99 Posted July 19, 2015 Report Share Posted July 19, 2015 Kevin: You might check my post on the "Rattle drive me crazy" topic that Frank mentioned. I originally thought the rattle and squeak was coming from the cup holder area but it turned out the be the plastic trim strip at the top of the center console on the passenger side. When you press down on the cup holder area you may be impacting the trim. Good luck! Be well... Quote Link to comment Share on other sites More sharing options...
FordCyp Posted September 11, 2016 Report Share Posted September 11, 2016 I had the same issue with my 2016 Titanium, only when the interior was very hot after being parked in the sun for hours... Drove me crazy. Applying pressure on the cup holder area stopped the vibration. Gave it to the dealer for a few days until they could hear it themselves... They took apart the console ... Loose rivet was glued, and adhesive foam applied on the seams of the cup holder ... Problem solved 1 Quote Link to comment Share on other sites More sharing options...
gjb89 Posted October 7, 2016 Report Share Posted October 7, 2016 Any clue where this rivet is? The dealership was unsuccessful for fixing my rattle. I've even tried the weather striping on the inside of the trim pieces on the sides of the console. Quote Link to comment Share on other sites More sharing options...
Tjm623 Posted October 8, 2016 Report Share Posted October 8, 2016 I have a rattle too, but I think mine is that little pull out drawer. Try pushing in on that and see of rattle stops Quote Link to comment Share on other sites More sharing options...
gjb89 Posted October 9, 2016 Report Share Posted October 9, 2016 Well I used felt on pretty much every piece of plastic that makes contact with another piece of plastic on the center console. Rattles gone now. Quote Link to comment Share on other sites More sharing options...
WFDEdge Posted October 21, 2016 Report Share Posted October 21, 2016 I have in that same area as well as the arm rest. The rattle seems to come from the passenger's side hinge for the arm rest. Drives me crazy. Quote Link to comment Share on other sites More sharing options...
