Frank Drebin Posted October 2, 2015 Author Report Share Posted October 2, 2015 On 10/1/2015 at 2:26 AM, rudeboie said: I got a squeaking noise coming from insude the headliner driver side near the door. Sounds like two pieces of plastic or hard rubber rubbing each other. Dealer found nothing, of course. No biggie, just annoying when the music's off. Also the Vista glass in the rear makes a creak or snapping sound whenever the body flexes (i drive up and down ramps alot since i live in a condo with 3 levels of underground parking i need to drive down/up. If it weren't for these annoyances, the car would have been perfect ... so far. Same thing here about: "Vista glass in the rear makes a creak or snapping sound whenever the body flexes" ... !?$@#% Quote Link to comment Share on other sites More sharing options...
Frank Drebin Posted October 2, 2015 Author Report Share Posted October 2, 2015 On 9/30/2015 at 4:51 PM, WingNut said: I think I'm hearing the backseat rattle on mine now. Any updates? I'm dropping the Edge to my dealer Monday morning (October 5) to fix (I wish) all the trouble... Quote Link to comment Share on other sites More sharing options...
WingNut Posted October 12, 2015 Report Share Posted October 12, 2015 Updates? Backseat rattle is starting to get annoying. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted October 12, 2015 Report Share Posted October 12, 2015 Any possibility that it's a (slightly) loose jack in the spare tire well? Had a sound simular to that once in my old car. Drove me nuts, sound travels, sounded like it was coming from under rear seat. Quote Link to comment Share on other sites More sharing options...
WingNut Posted October 12, 2015 Report Share Posted October 12, 2015 On 10/12/2015 at 3:10 PM, enigma-2 said: Any possibility that it's a (slightly) loose jack in the spare tire well? Had a sound simular to that once in my old car. Drove me nuts, sound travels, sounded like it was coming from under rear seat. I'll give it a look today and see if I can find anything loose. But I feel it is coming directly from the backseat. Quote Link to comment Share on other sites More sharing options...
Rextang Posted October 12, 2015 Report Share Posted October 12, 2015 Does it sound like marbles rattling around over your head? http://www.fordedgeforum.com/topic/18978-headliner-magnet-rattle-vista-roof/?do=findComment&comment=139316 Quote Link to comment Share on other sites More sharing options...
Frank Drebin Posted October 15, 2015 Author Report Share Posted October 15, 2015 Finally, having the work done on my Edge. 1- They change both rail for the pano roof ("toc" while opening gone...) SOLVE 2- Rattle under the bench of the rear seat... After searching...didn't found something wrong !!?!?! NOT SOLVE 3- Weird sound over my head (roof? headliner?) while the body structure are under light torsion... NOT SOLVE For #2... I'm testing something else tomorrow For #3... I do not find where (exactly) the sound is coming.... 1 Quote Link to comment Share on other sites More sharing options...
WingNut Posted October 15, 2015 Report Share Posted October 15, 2015 Frank thanks for the update. Keep us posted on #2 with your test. Quote Link to comment Share on other sites More sharing options...
Frank Drebin Posted October 16, 2015 Author Report Share Posted October 16, 2015 FOUND!! Under the bench of the rear seat, passenger side, left bracket who fix the rest on the floor 1 Quote Link to comment Share on other sites More sharing options...
WingNut Posted October 16, 2015 Report Share Posted October 16, 2015 Did you tighten it down? Quote Link to comment Share on other sites More sharing options...
Frank Drebin Posted October 16, 2015 Author Report Share Posted October 16, 2015 It's not the problem. The dealer remove the nut and tightened it down correctly. I'm gonna put a layer of foam between the parts and try it again on the road during the week-end Quote Link to comment Share on other sites More sharing options...
WingNut Posted October 16, 2015 Report Share Posted October 16, 2015 So foam between the bracket and body? Quote Link to comment Share on other sites More sharing options...
Frank Drebin Posted October 16, 2015 Author Report Share Posted October 16, 2015 On 10/16/2015 at 6:06 PM, WingNut said: So foam between the bracket and body? Exact! It's the next thing i'm gonna try Quote Link to comment Share on other sites More sharing options...
WingNut Posted October 16, 2015 Report Share Posted October 16, 2015 On 10/16/2015 at 6:24 PM, Frank Drebin said: Exact! It's the next thing i'm gonna try Keep us posted. I may try the same over the weekend. Quote Link to comment Share on other sites More sharing options...
built2prfctn Posted October 16, 2015 Report Share Posted October 16, 2015 GREAT FIND FRANK!! I will also be doing this. Thanks again. that god dam noise!!! Quote Link to comment Share on other sites More sharing options...
Frank Drebin Posted October 19, 2015 Author Report Share Posted October 19, 2015 I did it during the week-end and...it's FIX!! I use foam used under Wood floor. Quote Link to comment Share on other sites More sharing options...
WingNut Posted October 19, 2015 Report Share Posted October 19, 2015 On 10/19/2015 at 9:04 PM, Frank Drebin said: I did it during the week-end and...it's FIX!! I use foam used under Wood floor. What size socket did you use? Quote Link to comment Share on other sites More sharing options...
Frank Drebin Posted October 20, 2015 Author Report Share Posted October 20, 2015 16mm / 4 bolts with a rench Quote Link to comment Share on other sites More sharing options...
built2prfctn Posted October 20, 2015 Report Share Posted October 20, 2015 So to get to here- all I need to do is remove the bottom part of the seat? Quote Link to comment Share on other sites More sharing options...
WingNut Posted October 20, 2015 Report Share Posted October 20, 2015 On 10/20/2015 at 11:35 AM, built2prfctn said: So to get to here- all I need to do is remove the bottom part of the seat? Yes Quote Link to comment Share on other sites More sharing options...
WingNut Posted October 20, 2015 Report Share Posted October 20, 2015 On 10/20/2015 at 3:40 AM, Frank Drebin said: 16mm / 4 bolts with a rench So you put foam under all 4 posts/supports that mount to the body on the passenger side of the vehicle? Quote Link to comment Share on other sites More sharing options...
Frank Drebin Posted October 20, 2015 Author Report Share Posted October 20, 2015 Exact, remove the bench, unbolt the 2 bolt you see, flip down the rear rest, unbolt the 2 other bolt, move up the rear rest and put the foam under the metal bracket between the bracket (black) ans the tole (white). Quote Link to comment Share on other sites More sharing options...
