HOWL OR GROWL TYPE-NOISE FROM REAR WHEEL AREA
TSB 14-0098 (supersedes TSB 12-8-10)
Publication Date: May 3, 2014
FORD: 2007-2010 Edge
LINCOLN: 2007-2010 MKX
This article supersedes TSB 12-8-10 to update the Title, Issue Statement and Service Procedure.
ISSUE:
Some 2007-2010 Edge and MKX vehicles may exhibit a customer concern of a growl or howl type-noise coming from the left or right rear wheel area.
ACTION:
Follow the Service Procedure step to correct the condition.
SERVICE PROCEDURE
Replace the suspect rear wheel hub and bearing assembly with a new service part. Refer to Workshop Manual (WSM), Section 204-02.
PART NUMBER PART NAME
7T4Z-1104-B Hub Assy – FWD (2007-2008)
7T4Z-1104-C Hub Assy – 4WD
9T4Z-1104-A Hub Assy – FWD (2009–2010)
W712435-S439 Wheel Hub Nut – 4WD Inner & Outer (2 Req)
W520215-S440 Nut – Toe Link & Lower Arm Outboard (2 Req)
W500766-S439 Bolt – Toe Link & Lower Arm Outboard (2 Req)
W712459-S439 Bolt – Shock Absorber Lower Flag
W520214-S440 Nut – Shock Absorber Lower
W520414-S441 Nut – Stabilizer Bar Link
W712754-S439 Wheel Hub Bolt (4 Req)
OPERATION DESCRIPTION TIME
140098A 2007-2010 Edge/MKX FWD: Replace One (1) Rear Wheel Hub And Bearing (Do Not Use With Any Other Labor Operations) 0.6 Hr.
140098A 2007-2010 Edge/MKX AWD: Replace One (1) Rear Wheel Hub And Bearing (Do Not Use With Any Other Labor Operations) 1.2 Hrs.
140098B 2007-2010 Edge/MKX FWD: Replace Both (2) Rear Wheel Hub And Bearings (Do Not Use With Any Other Labor Operations) 1.0 Hr.
140098B 2007-2010 Edge/MKX AWD: Replace Both (2) Rear Wheel Hub And Bearings (Do Not Use With Any Other Labor Operations) 2.2 Hrs.
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
DEALER CODING
BASIC PART NO. CONDITION CODE
1104 d4
