WWWPerfA_ZN0W Posted July 7, 2015 Report Share Posted July 7, 2015 TSB 14-0059MIL ON WITH DTCS – P0351, P0352, P0353, P0354, P0355, AND/OR P0356 – BUILT ON OR BEFORE 3/1/2008Publication Date: March 20, 2014FORD: 2006-2008 Fusion; 2007-2008 Edge; 2008 Taurus, Taurus XLINCOLN: 2006 Zephyr; 2007-2008 MKX, MKZMERCURY: 2006-2008 Milan; 2008 SableThis article supersedes TSB 13-4-17 to update the Service Procedure and Part List.ISSUE:Some 2006 Zephyr, 2006-2008 Fusion, Milan, 2007-2008 MKZ, Edge, MKX, and 2008 Taurus, Taurus X and Sable vehicles built on or before 3/1/2008 and equipped with a 3.0L or 3.5L engine may exhibit a malfunction indicator lamp (MIL) on with diagnostic trouble codes (DTCs) P0351, P0352, P0353, P0354, P0355 and/or P0356 present in the Powertrain Control Module (PCM) and with one or more damaged ignition coil-on-plug(s).ACTION:Follow the Service Procedure steps to correct the condition.SERVICE PROCEDURE1.Using the IDS scan tool, retrieve continuous memory DTCs. Are DTCs P035X present in the PCM? a.No – this article does not apply. Refer to the Powertrain Control/Emissions Diagnosis (PC/ED) manual for normal diagnostics. b.Yes – proceed to Step 2.2.Remove only the spark plug(s) and ignition coil-on-plug(s) from the affected cylinder(s). Refer to Workshop Manual (WSM), Section 303-07.3.Inspect the ignition coil-on-plug(s) that have been removed for cracks and/or signs of heat related damage. Refer to Figures 1-3 at the end of this procedure for examples of damage. Does the ignition coil-on-plug(s) inspected show signs of damage? a.Yes – proceed to Step 4. b.No – replace only the spark plug(s) from the cylinders(s) associated with the P035X DTCs and do not continue with this article. Refer to the PC/ED manual for normal diagnostics.4.Review the Online Automotive Service Information System (OASIS) repair history to determine if a PCM with an RM part number suffix has been installed previously. Has a PCM with an RM part number suffix been installed previously? (e.g. XXXX-12A650-XXRM) a.No – proceed to step 5. b.Yes – replace only the ignition coil-on-plug(s) and the spark plug(s) for the affected cylinder(s) and do not continue with this article. Refer to the PC/ED manual for normal diagnostics.5.Replace the ignition coil-on-plug(s) and the spark plug(s) for the affected cylinder(s). Refer to WSM, Section 303-07.6.Replace the PCM. Refer to WSM, Section 303-14A.PART NUMBER PART NAMEAGSF-32W-M 3.0L Spark PlugAYFS-22F-M 3.5L Spark Plug6E5Z-12029-BA 3.0L Coil On Plug7T4Z-12029-E 3.5L Coil On Plug3F1Z-9H486-AA 3.0L Upper Intake Gasket7T4Z-9H486-DA 3.5L Upper Intake Gasket12A650 See Parts CatalogOPERATION DESCRIPTION TIME140059A 2007-2008 Edge/MKX: Check DTCs Replace One Spark Plug On The Right Side Of The Engine, Inspect The Ignition Coil (Can Be Claimed With Operations C Or D And E) 0.9 Hr.140059A 2008 Taurus/Sable/Taurus X: Check DTCs Replace One Spark Plug On The Right Side Of The Engine, Inspect The Ignition Coil (Can Be Claimed With Operations C Or D And E) 0.9 Hr.140059A 2006 Zephyr 2006-2008 Milan/Fusion: Check DTCs Replace One Spark Plug On The Right Side Of The Engine, Inspect The Ignition Coil (Can Be Claimed With Operations C Or D And E) 1.4 Hrs.140059A 2007-2008 MKZ: Check DTCs Replace One Spark Plug On The Right Side Of The Engine, Inspect The Ignition Coil (Can Be Claimed With Operations C Or D And E) 0.8 Hr.140059B 2007-2008 Edge/MKX: Check DTCs Replace Two Or More Spark Plugs On The Right Side Of The Engine, Inspect The Ignition Coils (Can Be Claimed With Operations C Or D And E) 1.1 Hrs.140059B 2008 Taurus/Sable/Taurus X: Check DTCs Replace Two Or More Spark Plugs On The Right Side Of The Engine, Inspect The Ignition Coils (Can Be Claimed With Operations C Or D And E) 1.1 Hrs.140059B 2006 Zephyr 2006-2008 Milan/Fusion: Check DTCs Replace Two Or More Spark Plugs On The Right Side Of The Engine, Inspect The Ignition Coils (Can Be Claimed With Operations C Or D And E) 1.6 Hrs.140059B 2007-2008 MKZ: Check DTCs Replace Two Or More Spark Plugs On The Right Side Of The Engine, Inspect The Ignition Coils (Can Be Claimed With Operations C Or D And E) 1.1 Hrs.140059C 2007-2008 Edge/MKX: Check DTCs Replace One Spark Plug On The Left Side Of The Engine, Inspect The Ignition Coil (Can Be Claimed With Operations A Or B And E) 0.4 Hr.140059C 2008 Taurus/Sable/Taurus X: Check DTCs Replace One Spark Plug On The Left Side Of The Engine, Inspect The Ignition Coil (Can Be Claimed With Operations A Or B And E) 0.4 Hr.140059C 2006 Zephyr 2006-2008 Milan/Fusion: Check DTCs Replace One Spark Plug On The Left Side Of The Engine, Inspect The Ignition Coil (Can Be Claimed With Operations A Or B And E) 0.5 Hr.140059C 2007-2008 MKZ: Check DTCs Replace One Spark Plug On The Left Side Of The Engine, Inspect The Ignition Coil (Can Be Claimed With Operations A Or B And E) 0.4 Hr.140059D 2007-2008 Edge/MKX: Check DTCs Replace Two Or More Spark Plugs On The Left Side Of The Engine, Inspect The Ignition Coils (Can Be Claimed With Operations A Or B And E) 0.6 Hr.140059D 2008 Taurus/Sable/Taurus X: Check DTCs Replace Two Or More Spark Plugs On The Left Side Of The Engine, Inspect The Ignition Coils (Can Be Claimed With Operations A Or B And E) 0.6 Hr.140059D 2006 Zephyr 2006-2008 Milan/Fusion: Check DTCs Replace Two Or More Spark Plugs On The Left Side Of The Engine, Inspect The Ignition Coils (Can Be Claimed With Operations A Or B And E) 0.7 Hr.140059D 2007-2008 MKZ: Check DTCs Replace Two Or More Spark Plugs On The Left Side Of The Engine, Inspect The Ignition Coils (Can Be Claimed With Operations A Or B And E) 0.6 Hr.140059E 2007-2008 Edge/MKX: Additional Time To Replace The PCM And The Ignition Coils As Needed Only If Ignition Coils Were Faulty (Must Be Claimed With Operation A, B, C, Or D) 0.3 Hr.140059E 2008 Taurus/Sable/Taurus X: Additional Time To Replace The PCM And The Ignition Coils As Needed Only If Ignition Coils Were Faulty (Must Be Claimed With Operation A, B, C, Or D) 0.7 Hr.140059E 2006 Zephyr 2006-2008 Milan/Fusion 2007-2008 MKZ: Additional Time To Replace The PCM And The Ignition Coils As Needed Only If Ignition Coils Were Faulty (Must Be Claimed With Operation A, B, C, Or D) 0.6 Hr.WARRANTY STATUSEligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage.Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.DEALER CODINGBASIC PART NO. CONDITION CODE12A650 42Figure 1 – 14-0059Figure 2 – 14-0059Figure 3 – 14-0059 Quote Link to comment Share on other sites More sharing options...
unhapfordownr Posted March 24, 2016 Report Share Posted March 24, 2016 This needs to be a recall not a TSB! I have found many people with the same issue. My edge broke down in the middle of rush hour traffic with no warning at all my check engine didnt even cut on until after I turned it off and restarted to see if it would strat again. Shakes violently and has no power to go. It is an over $2000.00 repair on top of the $700 I have already spent to replace output and input shaft speed sensors 6 months ago! I have only had my edge 14 months and have already put almost $3000.00 into it. Both issues have happened in rush hour traffic with no warning at ALL! I take good care of my edge and just had 4 new tires and brakes all the way around put on 2 weeks before my PCM and coils went out on it. FORD PLEASE PLEASE PLEASE ISSUE A RECALL!!! I could have been killed by my Edge losing power in the middle of 6 lanes of rush hour traffic with no warning not to mention the fact that this issue could cause engine to catch fire if there is gas in spark plugs!!! Quote Link to comment Share on other sites More sharing options...
unhapfordownr Posted March 24, 2016 Report Share Posted March 24, 2016 TSB 14-0059 MIL ON WITH DTCS – P0351, P0352, P0353, P0354, P0355, AND/OR P0356 – BUILT ON OR BEFORE 3/1/2008 Publication Date: March 20, 2014 FORD: 2006-2008 Fusion; 2007-2008 Edge; 2008 Taurus, Taurus X LINCOLN: 2006 Zephyr; 2007-2008 MKX, MKZ MERCURY: 2006-2008 Milan; 2008 Sable This article supersedes TSB 13-4-17 to update the Service Procedure and Part List. ISSUE: Some 2006 Zephyr, 2006-2008 Fusion, Milan, 2007-2008 MKZ, Edge, MKX, and 2008 Taurus, Taurus X and Sable vehicles built on or before 3/1/2008 and equipped with a 3.0L or 3.5L engine may exhibit a malfunction indicator lamp (MIL) on with diagnostic trouble codes (DTCs) P0351, P0352, P0353, P0354, P0355 and/or P0356 present in the Powertrain Control Module (PCM) and with one or more damaged ignition coil-on-plug(s). ACTION: Follow the Service Procedure steps to correct the condition. SERVICE PROCEDURE 1.Using the IDS scan tool, retrieve continuous memory DTCs. Are DTCs P035X present in the PCM? a.No – this article does not apply. Refer to the Powertrain Control/Emissions Diagnosis (PC/ED) manual for normal diagnostics. b.Yes – proceed to Step 2. 2.Remove only the spark plug(s) and ignition coil-on-plug(s) from the affected cylinder(s). Refer to Workshop Manual (WSM), Section 303-07. 3.Inspect the ignition coil-on-plug(s) that have been removed for cracks and/or signs of heat related damage. Refer to Figures 1-3 at the end of this procedure for examples of damage. Does the ignition coil-on-plug(s) inspected show signs of damage? a.Yes – proceed to Step 4. b.No – replace only the spark plug(s) from the cylinders(s) associated with the P035X DTCs and do not continue with this article. Refer to the PC/ED manual for normal diagnostics. 4.Review the Online Automotive Service Information System (OASIS) repair history to determine if a PCM with an RM part number suffix has been installed previously. Has a PCM with an RM part number suffix been installed previously? (e.g. XXXX-12A650-XXRM) a.No – proceed to step 5. b.Yes – replace only the ignition coil-on-plug(s) and the spark plug(s) for the affected cylinder(s) and do not continue with this article. Refer to the PC/ED manual for normal diagnostics. 5.Replace the ignition coil-on-plug(s) and the spark plug(s) for the affected cylinder(s). Refer to WSM, Section 303-07. 6.Replace the PCM. Refer to WSM, Section 303-14A. PART NUMBER PART NAME AGSF-32W-M 3.0L Spark Plug AYFS-22F-M 3.5L Spark Plug 6E5Z-12029-BA 3.0L Coil On Plug 7T4Z-12029-E 3.5L Coil On Plug 3F1Z-9H486-AA 3.0L Upper Intake Gasket 7T4Z-9H486-DA 3.5L Upper Intake Gasket 12A650 See Parts Catalog OPERATION DESCRIPTION TIME 140059A 2007-2008 Edge/MKX: Check DTCs Replace One Spark Plug On The Right Side Of The Engine, Inspect The Ignition Coil (Can Be Claimed With Operations C Or D And E) 0.9 Hr. 140059A 2008 Taurus/Sable/Taurus X: Check DTCs Replace One Spark Plug On The Right Side Of The Engine, Inspect The Ignition Coil (Can Be Claimed With Operations C Or D And E) 0.9 Hr. 140059A 2006 Zephyr 2006-2008 Milan/Fusion: Check DTCs Replace One Spark Plug On The Right Side Of The Engine, Inspect The Ignition Coil (Can Be Claimed With Operations C Or D And E) 1.4 Hrs. 140059A 2007-2008 MKZ: Check DTCs Replace One Spark Plug On The Right Side Of The Engine, Inspect The Ignition Coil (Can Be Claimed With Operations C Or D And E) 0.8 Hr. 140059B 2007-2008 Edge/MKX: Check DTCs Replace Two Or More Spark Plugs On The Right Side Of The Engine, Inspect The Ignition Coils (Can Be Claimed With Operations C Or D And E) 1.1 Hrs. 140059B 2008 Taurus/Sable/Taurus X: Check DTCs Replace Two Or More Spark Plugs On The Right Side Of The Engine, Inspect The Ignition Coils (Can Be Claimed With Operations C Or D And E) 1.1 Hrs. 140059B 2006 Zephyr 2006-2008 Milan/Fusion: Check DTCs Replace Two Or More Spark Plugs On The Right Side Of The Engine, Inspect The Ignition Coils (Can Be Claimed With Operations C Or D And E) 1.6 Hrs. 140059B 2007-2008 MKZ: Check DTCs Replace Two Or More Spark Plugs On The Right Side Of The Engine, Inspect The Ignition Coils (Can Be Claimed With Operations C Or D And E) 1.1 Hrs. 140059C 2007-2008 Edge/MKX: Check DTCs Replace One Spark Plug On The Left Side Of The Engine, Inspect The Ignition Coil (Can Be Claimed With Operations A Or B And E) 0.4 Hr. 140059C 2008 Taurus/Sable/Taurus X: Check DTCs Replace One Spark Plug On The Left Side Of The Engine, Inspect The Ignition Coil (Can Be Claimed With Operations A Or B And E) 0.4 Hr. 140059C 2006 Zephyr 2006-2008 Milan/Fusion: Check DTCs Replace One Spark Plug On The Left Side Of The Engine, Inspect The Ignition Coil (Can Be Claimed With Operations A Or B And E) 0.5 Hr. 140059C 2007-2008 MKZ: Check DTCs Replace One Spark Plug On The Left Side Of The Engine, Inspect The Ignition Coil (Can Be Claimed With Operations A Or B And E) 0.4 Hr. 140059D 2007-2008 Edge/MKX: Check DTCs Replace Two Or More Spark Plugs On The Left Side Of The Engine, Inspect The Ignition Coils (Can Be Claimed With Operations A Or B And E) 0.6 Hr. 140059D 2008 Taurus/Sable/Taurus X: Check DTCs Replace Two Or More Spark Plugs On The Left Side Of The Engine, Inspect The Ignition Coils (Can Be Claimed With Operations A Or B And E) 0.6 Hr. 140059D 2006 Zephyr 2006-2008 Milan/Fusion: Check DTCs Replace Two Or More Spark Plugs On The Left Side Of The Engine, Inspect The Ignition Coils (Can Be Claimed With Operations A Or B And E) 0.7 Hr. 140059D 2007-2008 MKZ: Check DTCs Replace Two Or More Spark Plugs On The Left Side Of The Engine, Inspect The Ignition Coils (Can Be Claimed With Operations A Or B And E) 0.6 Hr. 140059E 2007-2008 Edge/MKX: Additional Time To Replace The PCM And The Ignition Coils As Needed Only If Ignition Coils Were Faulty (Must Be Claimed With Operation A, B, C, Or D) 0.3 Hr. 140059E 2008 Taurus/Sable/Taurus X: Additional Time To Replace The PCM And The Ignition Coils As Needed Only If Ignition Coils Were Faulty (Must Be Claimed With Operation A, B, C, Or D) 0.7 Hr. 140059E 2006 Zephyr 2006-2008 Milan/Fusion 2007-2008 MKZ: Additional Time To Replace The PCM And The Ignition Coils As Needed Only If Ignition Coils Were Faulty (Must Be Claimed With Operation A, B, C, Or D) 0.6 Hr. WARRANTY STATUS Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage. Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. DEALER CODING BASIC PART NO. CONDITION CODE 12A650 42 TSB14-0059PICa.jpg Figure 1 – 14-0059 TSB14-0059PICb.jpg Figure 2 – 14-0059 TSB14-0059PICc.jpg Figure 3 – 14-0059 Quote Link to comment Share on other sites More sharing options...
akirby Posted March 24, 2016 Report Share Posted March 24, 2016 Ok, you vented your frustration and that's fine, but let's not keep repeating the same post over and over please. This is not a recall issue - that's reserved for things the government deems to be safety related and this doesn't qualify (I understand you disagree but you need to talk to the NHTSA about that). Your vehicle is 10 years old. Even if they had extended the warranty on these components you probably wouldn't be covered. You can probably find a used PCM and new coils at an independent shop for a lot less. 1 Quote Link to comment Share on other sites More sharing options...
Waldo Posted March 24, 2016 Report Share Posted March 24, 2016 fact that this issue could cause engine to catch fire if there is gas in spark plugs!!! Uh, the purpose of a spark plug is to light gas on fire. Your engine doesn't run specifically because the spark plugs are unable to light the gas on fire Quote Link to comment Share on other sites More sharing options...
luminator Posted March 24, 2016 Report Share Posted March 24, 2016 Uh, the purpose of a spark plug is to light gas on fire. Your engine doesn't run specifically because the spark plugs are unable to light the gas on fire And gas does not go in the spark plug?. It is a break down of an 7-10 year old vehicle that is outside factory warranty, its the same as a fuel pump failure, ECM frying, ect. It sucks that it happens but it is not causing fires, exploding tires, cruise control or the GM electric steering failure on the Cobalts all which caused serious or life threatening accidents. Yes a vehicle dying on the freeway is dangerous but it does not come to a crashing stop, you lose power and drift to a stop. It is not a Recall reason, suck up it up and pay for your repair, it is part of older vehicle ownership. Quote Link to comment Share on other sites More sharing options...
