jerrywest97 Posted July 7, 2015 Report Share Posted July 7, 2015 My 2011 Edge touch screen has intermittently begun to go black. I have at times been able to remove the not as much luck. in the past i have been able to pull the fuse and fuse and it power back up with the replacement of said fuse. Today I am having the same problem, but not as much luck with the reboot. IO read today that there is a glich in the programming that causes them to do that. Have they come up with a fix? Quote Link to comment Share on other sites More sharing options...
omar302 Posted July 7, 2015 Report Share Posted July 7, 2015 Take it to your dealer, they should try a reflash, if it doesn't work, I believet hey should change the APIM. You have a 5 year extended warrantyo n the APIM (software & hardware) with unlimited mileage. Quote Link to comment Share on other sites More sharing options...
