4.2 INCH DISPLAY RADIO – UP/DOWN ARROW BUTTONS INOPERATIVE
TSB 14-0050
Publication Date: March 10, 2014
FORD: 2013 Edge; 2014 Explorer, Flex, Taurus
ISSUE:
Some 2013 Edge vehicles built on 8/16/2013 and through 9/27/2013, 2014 Explorer vehicles built on 8/23/2013 and through 9/27/2013, Flex vehicles built on 8/29/2013 and through 9/27/2013, and Taurus vehicles built on 8/22/2013 and through 9/27/2013, equipped with the 4.2 inch display radio only may exhibit the up/down keypad arrows being inoperative. This may be due to the Front Control Display Interface Module (FCDIM) software.
ACTION:
Reprogram the FCDIM module to the latest calibration using IDS release 89.04 and higher. Calibration files may also be obtained at www.motorcraftservice.com.
OPERATION DESCRIPTION TIME
140050A Reprogram The FCDIM Includes Time To Clear Codes After Repair (Do Not Use With Any Other Labor Operations) 0.3 Hr.
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
DEALER CODING
BASIC PART NO. CONDITION CODE
10D885 04
Ford Module Programming (FMP) is a software application that allows subscribers to program electronic modules on Ford, Lincoln and Mercury vehicles. It can be used for:
•Reprogramming emission-related (OBDII) modules on some vehicles manufactured in 1995 and all vehicles manufactured from 1996 to the present
•Reprogramming or reconfiguring non-emission-related modules on many vehicles (UBP and MS-CAN not supported)
In addition, module initialization (PATS) functions such as Keycode Erase/Reprogram and PCM Parameter Reset can be done using this application.
J2534 Device using Ford Module Programming (FMP) can Reprogram and Configure most Modules.
