Grinding noise axle area
mswandog
Found the outer CV joint bad on driver side...127k miles... suspension has lowering springs...I found it quicker to replace lower A-arms with ball joint and sway bar end links...I also purchase the whole axle and changed both left and right...Note: the passenger side needed a little persuasion getting away from the intermediate shaft.
