ExNascarDood Posted June 21, 2015 Report Share Posted June 21, 2015 I'm looking to replace the stock 3157 Amber front turn signal bulbs with amber LED's. I'm In Canada (eh lol) so my '13 SEL used the headlights for DRL's so the turn signals aren't used for that purpose. What is the best LED I buy for this application? Through searching I've found some require a resistor to be added and would like to avoid that if at all possible. Thanks in advance Quote Link to comment Share on other sites More sharing options...
candurin Posted June 21, 2015 Report Share Posted June 21, 2015 The XP80 ambers from diode dynamics will be your brightest option. It will cost you, though. The only LED's I have purchased from the are my switchbacks and I have never been happier. They have outlasted all my other attempts at other brand switchbacks. http://www.diodedynamics.com/store/2011-2013-ford-edge-front-turn-signal-leds-pair Unfortunately you can't get away from a resistor. But if you use scotchloks to splice the wires (mine have been in for over 3 years without any issues), it will take less than 5 minutes to install. 2 Quote Link to comment Share on other sites More sharing options...
ExNascarDood Posted June 22, 2015 Author Report Share Posted June 22, 2015 Thanks, So I'd choose the 6K White + amber option and then 1 of 3 brightness. How bright are the XP80's? I have 6K HID's and don't want to get flashed or pulled over so I'm thinking the HP11 option might be the way to go ...... Quote Link to comment Share on other sites More sharing options...
candurin Posted June 22, 2015 Report Share Posted June 22, 2015 (edited) If you're going for switchbacks, then the HP24 is your only option. If you want Amber only version, then I would go with the XP80. Either option needs a resistor. That's what I have in my edge and they look great with plenty of brightness. Never been flashed once. Edited June 22, 2015 by candurin 1 Quote Link to comment Share on other sites More sharing options...
ExNascarDood Posted June 22, 2015 Author Report Share Posted June 22, 2015 Doh - thanks for clearing that up! Now I need to decide if I want switchbacks or not. I assume the "set" of resistors is 4 as the video shows positive and negative connections for each lamp. Where did you mount the resistors to and what did you use to mount them. Historically, I've found it to be quite the biatch to drill into hardened steel on auto's - especially when using small bits for small screws. Quote Link to comment Share on other sites More sharing options...
TheWizard Posted June 22, 2015 Report Share Posted June 22, 2015 Two sided tape is quite sufficient for mounting the resistors. Just clean the mounting surface thoroughly with alcohol and they will stay put basically forever (they don't weigh very much so there is nothing pulling them loose). 2 Quote Link to comment Share on other sites More sharing options...
ExNascarDood Posted June 22, 2015 Author Report Share Posted June 22, 2015 Thanks Wizard! I was concerned the heat from the resistors would play havoc with the adhesive in such tape. I have access to high quality automotive tapes so I'll get some good double sided tape and go for it. Once I get under the hood with the resistors between the tape and some tie wraps on the wires I'm sure I'll mount those mofos up so they aren't a problem! Quote Link to comment Share on other sites More sharing options...
TheWizard Posted June 23, 2015 Report Share Posted June 23, 2015 Assuming you get the resistors that are designed specifically for turn signal use, you won't have a problem with heat. The resistor is enclosed in a heat sink housing that will get warm but not hot enought that you would find it uncomfortable to touch. The flat back is ideal for using two-sided tape. (These ones are $9 for four on Amazon) 1 Quote Link to comment Share on other sites More sharing options...
