which gear to use for towing?
Hi,
I have a 2013 Ford Edge SEL FWD, 3.5L. I am towing a 2000Lbs boat and I don't have the Overdrive Off switch.
The only thing I found on Ford website was that only uphill I should change my shift to S mode and then downshift to the 5th gear.
Is here a better recommendation?
Thanks a lot.
Driving With An Automatic Overdrive Transmission
With certain automatic overdrive transmissions, towing – especially in hilly areas – may cause excessive shifting between overdrive and the next lower gear.
– To eliminate this condition and achieve steadier performance, overdrive can be locked out (see vehicle Owner’s Manual) – If excessive shifting does not occur, use overdrive to optimize fuel economy
– Overdrive may also be locked out to obtain engine braking on downgrades
Edited by callatis
  • 4 weeks later...
