macbwt Posted June 14, 2017 Author Report Share Posted June 14, 2017 Mac, my 2011's front suspension is starting to knock a little while going over bumps. I already did the swaybar links. What usually goes first up front??? Just hit 90 Grand. Gosh, I am at 200,000 just about. Only suspension work I have done to my Edge is new struts and strut bearing mounts. Check those and ball joints. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted June 17, 2017 Author Report Share Posted June 17, 2017 And part two of the water pump video dissection. Quote Link to comment Share on other sites More sharing options...
macbwt Posted June 17, 2017 Author Report Share Posted June 17, 2017 After about 8 times around the circumference of the earth and just 40K miles short of a one way trip to the moon. My Edge LU has now developed wheel bearing failure. Not exactly sure which wheel(s) but I will let it ride just a bit longer to make it easier to determine the failed wheel then if it is the back I will replace both rears and so on. Either way I will be replacing ALL four wheel bearings shortly. Now just to decided do I go with OEM motorcraft, SKF, Timken or Moog so many decisions. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 17, 2017 Report Share Posted June 17, 2017 Wow, the moon is REALLY close. I hope it doesn't fall out of the sky someday. LOL. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted June 23, 2017 Author Report Share Posted June 23, 2017 The Ford Edge Easter Egg. Have fun. 2 Quote Link to comment Share on other sites More sharing options...
macbwt Posted July 3, 2017 Author Report Share Posted July 3, 2017 The infamous washer jet assembly replacement on my wife's Ford Edge. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted July 14, 2017 Author Report Share Posted July 14, 2017 (edited) Long term effort to test oils with the duratec 3.5. I have ran various oils to date through my 3.5 Duratec on both of my 2011 Edge's. I am now changing the oil brand for the 5th time. I have ran a synblend bulk oil initially with bulk filter then changed to a AMSOIL with AMSOIL filter for multiple runs with the 0W20 and now I am using Mobile one with AMSOIL filter. I am now going to the the Purolator Boss oil filter and REDLINE 5W20 synthetic motor oil. I have testing from many of this oils under two entirely different extremes. 1) all city high idle time and 2) all interstate mileage. I run the same oils during the phase of the testing for Each brand The All city Edge is ran for 100 hrs and the All highway is ran for 200hrs Results so far have me against using 0W20 weight oil for any 3.5 for two reasons; 1) Bearing and high metals wear the oil is just too light for hard use 2) Highway use the extended drive hours (200) the Duratec consumes the oil through the PCV system and will use over a quart of oil during a 200 hr run. Currently I have mobile one and have lost just over half a quart in the 200hrs and the 100hr engine seem to be just slightly down at nearly 100hrs. Testing samples will be collected soon My goal is to build a data base of use in hours and type of oil my weight and brand and hopefully show how the oils behave with the 3.5 duratec. Edited July 14, 2017 by macbwt 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 17, 2017 Report Share Posted July 17, 2017 Great experiment. Consider adding Motorcraft blend as the Ford dealers now use. 2 Quote Link to comment Share on other sites More sharing options...
macbwt Posted July 17, 2017 Author Report Share Posted July 17, 2017 Great experiment. Consider adding Motorcraft blend as the Ford dealers now use. I am sticking with full synthetics as the blends IMO will not hold up to the high hours testing and the results will be incompatible to the synthetics. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted July 18, 2017 Author Report Share Posted July 18, 2017 Red Line oil change with Purolator Boss filter. This video is not a how to but a how Dad and daughter do things together. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted July 18, 2017 Author Report Share Posted July 18, 2017 Hello everyone, MAC T here and I am starting a new topic called double edged. The situation is as follows: I currently own and drive two Ford Edges. This topic will be used to follow two 2011 Ford Edge Limited as they both experience usage in opposition. The Blue Metallic 2011 (MOMOSHA Car) driven mostly city driving and virtually no highway vs the Cinnamon Metallic 2011 (work car) which will be driven 95 percent of the time on interstates in long haul driving situations. How will each one handle the different driving conditions? What repairs will result in the greatly different usage? Time will tell and it will be documented on this topic. Note: The documentation of most repairs will be on video. It has now been two years documenting the maintenance and repairs on both of the 2011 Edge's. So far pretty good results and both are still reliable and run very well. Had some repairs, but I would consider most to be under the consumable list. Let's see what the future holds as the miles build up. 1 Quote Link to comment Share on other sites More sharing options...
tanman_2006 Posted July 24, 2017 Report Share Posted July 24, 2017 Just spent the past 2 weeks reading your OC thread and this one. My head hurts... haha 2 Quote Link to comment Share on other sites More sharing options...
macbwt Posted August 13, 2017 Author Report Share Posted August 13, 2017 Had an idea and read the FSM on cleaning the HVAC so made the video on how to super clean your HVAC system in the Edge. I used my wife's Edge for this adventure. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted August 19, 2017 Author Report Share Posted August 19, 2017 Just in case you wanted to replace your blower motor in the HVAC system. Here it is. Quote Link to comment Share on other sites More sharing options...
macbwt Posted August 19, 2017 Author Report Share Posted August 19, 2017 Some folks always ask. Does a full sized spare fit in the back of the Edge. My response is can you get a square peg in a round hole? 2 Quote Link to comment Share on other sites More sharing options...
macbwt Posted August 25, 2017 Author Report Share Posted August 25, 2017 A video on how to remove the passenger side seat on the Ford Edge MY 2011. I am sure the drivers side will be forthcoming. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted August 26, 2017 Author Report Share Posted August 26, 2017 A quick easy way to check your water pump for leaks. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted September 18, 2017 Author Report Share Posted September 18, 2017 Blueberry's key fob button broke so I ordered a new case and got it working again. 15 dollar repair. 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted September 18, 2017 Report Share Posted September 18, 2017 Mac, did you try to glue the disc on the old remote first? It worked for me. What is strange is that your unlock button, seems you use it a lot, why not just pull the door handle & utilize the smart keyless entry? On my fob, the remote start button failed, and it is the one I press the most (double click to remote start). 2 Quote Link to comment Share on other sites More sharing options...
macbwt Posted September 20, 2017 Author Report Share Posted September 20, 2017 Mac, did you try to glue the disc on the old remote first? It worked for me. What is strange is that your unlock button, seems you use it a lot, why not just pull the door handle & utilize the smart keyless entry? On my fob, the remote start button failed, and it is the one I press the most (double click to remote start). You are a funny man assuming it was my remote. It is my wife's remote to her Edge and WE both will never know why she does not just grab the door handle to unlock the door. LOL You can ask her though, but I will not. LOL I could not find the missing piece and for 15 buck her remote now looks brand new. It was pretty worn and beat up from being in her purse. 2 Quote Link to comment Share on other sites More sharing options...
macbwt Posted September 30, 2017 Author Report Share Posted September 30, 2017 Hedging my bets and bought a new fan assembly for my wife's Edge Blueberry. She does a lot of idling and since she is nearly 96K miles I figure this saves me a phone call later while I am on the road and not home. Just replace the fan and hand on to the old one as a back up for LU since LU has 211,000 miles on her fan now. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted October 8, 2017 Author Report Share Posted October 8, 2017 Blueberry is getting a new set of cooling fans tomorrow. Just making sure it does not have any problems while I am gone on the road. I will keep the old fans for testing and maybe use in my other Edge if they ever fail. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted November 11, 2017 Author Report Share Posted November 11, 2017 Not wanting my wife to have a fan failure due to her high hours of idle so I replaced the fan assembly. 9 minutes later i was done. 2 Quote Link to comment Share on other sites More sharing options...
macbwt Posted November 26, 2017 Author Report Share Posted November 26, 2017 Getting ready for winter. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted January 4, 2018 Author Report Share Posted January 4, 2018 Cold weather was rather hard on the aging Michelin Latitudes. Had one go flat and the others were just having issues with holding air. Combination of old rubber and cold temps. Had a yokohama YK580 installed for now (had it laying around the garage) Next week the new Michelin Premier LTX's will be delivered and installed. Then I can test traction in snow vs the blizzaks. Worn Blizzaks vs New Michelins. Wonder which will win. 1 Quote Link to comment Share on other sites More sharing options...
