A/C question while towing.
While driving from TN to FL today, I noticed that the a/c would blow warmer humid air when we were going through the mountains, when the rpm was over 3500. The temp gauge did not move from the normal position.
I am towing a UHaul 5x9 utility trailer with my Honda Shadow and some houseplants on it, and the rear of the Edge has suitcases and the like with the seats folded down. The Tare weight for everything combined, including the Edge, is a little over 5000lbs, and the Gross weight is a little over 7000lbs.
Is it normal for the a/c to cut out when the engine is under heavy load?.
  • 2 months later...
