2012 Edge is in the shop
CinnamonEdge
So, The 2012 Edge is in the shop(dealer). Here is what is getting looked at/ done.
1. BAMR accordian black piece keeps detatching from track on bottom.
2. High pressure power steering line leaking.
3. Passenger side window glass has air pocket in laminate.
4. Drivers door AJAR warning when doors are closed.
5. Front Ford Emblem is starting to show moisture under clear coat on chrome.
6. HVAC temperature not accurate.
7. Funky shifts with transmission when coasting and then hitting gas.
6. Finally the standard Oil change.
BTW I only have 16,000 miles... We will see how this pans out.
PaulSchott and Closetotheedge FYI the Limited on the 2011 and up has laminated glass that adds to the sound proofing. The glass has two distinct layers and is about a .25" thick total thickness. So yes the front windshield is Soundscreen Glass and side glass on my Edge is Laminiated.
Edited by CinnamonEdge
