George Breland Posted June 8, 2015 Report Share Posted June 8, 2015 I replaced the spark plugs on my used 2011 ford edge and in reinstalling the upper intake manifold i noticed that the repair manual that i was useing called for a 2 step process to torque the manifold bolts. 1st step 89 inch lbs. OK got that. 2nd: "tighten an additional 45 degrees" this seems strange. that is a 1/4 turn 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted June 8, 2015 Report Share Posted June 8, 2015 Not actually all that unusual. Many manufacturers use this process. I believe there is a gauge or tool that can provide the 45 degree spec also. Quote Link to comment Share on other sites More sharing options...
autom8r Posted June 8, 2015 Report Share Posted June 8, 2015 Dora says: 360 degrees divided by 4 equals 90 degrees (quarter turn). 45 degrees is half of 90 degrees, so that is an eighth of a turn. 45 x 8 = 360. Quote Link to comment Share on other sites More sharing options...
macbwt Posted June 8, 2015 Report Share Posted June 8, 2015 Ya know I missed that in his statement. Glad you caught it. Off and back to 5th grade math for me. LOL Dora says:360 degrees divided by 4 equals 90 degrees (quarter turn).45 degrees is half of 90 degrees, so that is an eighth of a turn. 45 x 8 = 360. 1 Quote Link to comment Share on other sites More sharing options...
EdgeTech Posted January 19, 2020 Report Share Posted January 19, 2020 So I changed out my spark plugs in my 2011 Edge Sport 3.7l AWD. That went well actually except for me dropping and losing a bolt for some kinda support bracket thats under and behind the Throttle body. Theres only 1 bolt that goes back in there and I lost it. Does anyone know the specs of that bolt so I can replace it, or where to find a replacement?? Im not above going to the hardware store and getting a close match since its not going anywhere crucial like holding down the manifold. Quote Link to comment Share on other sites More sharing options...
Jack”O”Allmastr”O”Nutn Posted December 11, 2021 Report Share Posted December 11, 2021 There’s a lot of those Bolt missing mine was undone when I took mine apart Quote Link to comment Share on other sites More sharing options...
