ExNascarDood Posted June 6, 2015 Report Share Posted June 6, 2015 I have a 2013 AWD SEL with the 20" "Chrome" rims and 245/50/R20 tires. I have a chance to buy some steelies and snows from a friend who just sold his 2007 SEL FWD. Tires are 245/65/R17 so my speedo would be just a little slow - less than 1%. The question I have - and have searched for an answer for without any luck is - would rims that fit the '07 SEL FWD fit on my Edge in regard to bolt pattern and offset? I know dimensionally they'd be fit but I'm not sure about offset and bolt pattern. The Blizzack's have 1 season left on them and he just painted the steelies after using them last winter. I can grab them for $300 all in which is a pretty good deal with the pricing I have deal with for new rims and tires here in Canada. Only thing I'd need to do is add TPMS - if I need them (not sure yet) and set. So - am I good to go with these snows and steeliers from the 2007 or am I back in the market for winter traction? Thanks in advance Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 6, 2015 Report Share Posted June 6, 2015 As far as I remember, bolt pattern & offset should match, but they have a different hub size. '07-'10 & '11-'14 have different hub sizes. Don't remember which is smaller & which is bigger. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 6, 2015 Report Share Posted June 6, 2015 '11+ is smaller, at 63.4 mm, '07-'10 are the 70.6 mm hubs. Quote Link to comment Share on other sites More sharing options...
ExNascarDood Posted June 6, 2015 Author Report Share Posted June 6, 2015 Thanks everyone! So it looks like I may be out of luck unless the hub opening on the rims was larger than his hub. Totally forgot about that aspect of it. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted June 7, 2015 Report Share Posted June 7, 2015 Actually, you are in luck. It's easier to put larger hubbed wheels on smaller hubs (with hub adapters) rather than the other way round. Gets expensive to expand the bore of the wheel for a larger hub. What you need to get are 63.4 to 70.6 adapters. Quote Link to comment Share on other sites More sharing options...
