'07 Edge AWD SEL "Tire Pressure Monitor Fault" after changing to 20"
CivicSi907
Hi Guys,
about one week after changing my wheels from stock 17" to 20" "Tire Pressure Monitor Fault" blinks up in my Boardcomputer.
I checked pressure on all tires (all 56 psi) and its good.
I didn't put the TPMS Sensor in the wheels, didn't knew that I have to.
Is it possible to reset this fault message or do I have to add the TPMS sensors?
In the U.S., it's a federal requirement, so even if it could be turned off with IDS, no one would do it. You will have to install the sensors on the new wheels, sorry :( Should get new band sensors, EBay is a good place to get good prices on them.
as you know, I am located in germany! Its only required to new cars build 2014+.
Is it possible to turn it off permanent?
Edited by CivicSi907
